Codigos vagcom necesito una ayudita
Hola a todos tengo estos fallos despues de instalar el rns510 y una vw bt 7p6035730f con un fis-link os dejo esto por aki haber si entre todos me aclaró....
Thursday,02,February,2017,02:55:24:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 75 76
77
VIN: WVWZZZ1KZ8M141885 Mileage: 95590km/59396miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
75-Telematics -- Status: Not registered 0001
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 PP HW: 03G 906 021 AN
Component: R4 2,0L EDC G200SG 4661
Revision: --H07--- Serial number: VWX7Z0H124O04B
Coding: 0000072
Shop #: WSC 00916 572 83373
VCID: 7CF7127B3F1EBCFEC8B-8029
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0039554
Shop #: WSC 00066 000 00000
VCID: 68DF5E2B5B86005E3C3-803D
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CT HW: 1K0 907 044 CT
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 7BF511673A10BBC6C11-802E
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000000879453
Coding: E7030E2700041500470A00000F00000000095D035C00010000 0000000000
VCID: 71E9334F685CC1966BD-8024
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 230208 021 0501
Coding: 00038805
Shop #: WSC 00066
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 050108 046 0204
Coding: 00208933
Shop #: WSC 00066
1 Fault Found:
00061 - Footwell Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 14
Mileage: 61837 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.90 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 2J AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1PP35M
Coding: 0012874
VCID: 3D71DF7F648475F6BF5-8068
Subsystem 1 - Serial number: 6332MSME2D650A71F
Subsystem 2 - Serial number: 6342MSME2D6455108
Subsystem 3 - Serial number: 6351HSME127C243A8
Subsystem 4 - Serial number: 6361HSME127C1B057
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0100
Coding: 0003021
VCID: 78FF0E6B0B2690DEAC3-802D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Part No SW: 1K0 920 874 B HW: 1K0 920 874 B
Component: KOMBIINSTRUMENT 3HL 2216
Revision: V0002000 Serial number: VWX7Z0H124O04B
Coding: 0023103
Shop #: WSC 00916 572 93827
VCID: 2C57E23B8FFEEC7E18B-8079
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 060108F1001874
Coding: E9817F0E4006021002
Shop #: WSC 00916 572 87992
VCID: 306FF64BA3D6889E243-8065
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 94
Reset counter: 255
Mileage: 95488 km
Time Indication: 0
Date: 2000.00.00
Time: 16:20:45
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2216
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H10 5274
Revision: AB001001 Serial number: VWZ6Z7L5801082
Coding: 04000442040000110005
Shop #: WSC 01324 020 00200
VCID: 3B75D167BA907BC6811-806E
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 11
Mileage: 95488 km
Time Indication: 0
Date: 2000.00.00
Time: 13:40:18
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1133
Revision: 31008001 Serial number: 00000535588126
Coding: 0000182
VCID: 3C77D27B7F9E7CFE88B-8069
1 Fault Found:
00131 - Outside Door Handle Illumination/mirror Light Driver Side
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 254
Reset counter: 52
Mileage: 61837 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3561C75F5CB4ADB6775-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81900A0001060C7F2D0484057008CFC6F0FC00
VCID: 8305E987C2E04306091-80D6
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1133
Revision: 31008001 Serial number: 00000040088121
Coding: 0000438
2 Faults Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 32
Reset counter: 50
Mileage: 92031 km
Time Indication: 0
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Freeze Frame:
Fault Priority: 5
Reset counter: 52
Mileage: 61837 km
Time Indication: 0
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: F4E7BA5B974E74BE00B-80A1
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 11
Mileage: 95488 km
Time Indication: 0
Date: 2000.00.00
Time: 13:40:18
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000002727311
Coding: 0000144
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000002771573
Coding: 0000144
VCID: 3E73D87369826EEEA6F-806B
Address 75: Telematics
Cannot be reached
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 12 Einparkhilfe 0101
VCID: 2D51EF3FB4E4E5760F5-8078
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660350802
Coding: 0510000100010101
Shop #: WSC 00049 049 00247
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 3561C75F94B4ADB6775-8060
1 Fault Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 13
Mileage: 95524 km
Date: 2000.00.00
Time: 06:14:29
