AutoScan en mi Passat 3Bg
Mi autoscan
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 019 EP
Component: 1,9l R4 EDC 0000SG 1464
Coding: 00002
Shop #: WSC 00028
WVWZZZ3BZ2P288544 VWZ7Z0A4501082
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: N/A
(cierto de vez en cuando me falla la temperatura)
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 04255
Shop #: WSC 00028
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0006
Coding: 17000
Shop #: WSC 03403
2 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-10 - Faulty - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
(no tengo ni idea a que se refiere, supongo que algunos actuadores se quedaran pillados)
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B0 920 827 AX
Component: KOMBI+WEGFAHRSP VDO V10
Coding: 05115
Shop #: WSC 03403
1 Fault Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
(y este es el que acojona)
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 03403
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 03 Komfortgerát HLO 0001
Coding: 00259
Shop #: WSC 00028
2 Faults Found:
00912 - Window Regulator Switch: Front Left (E40)
27-10 - Implausible Signal - Intermittent
00913 - Window Regulator Switch: Front Right Driver (E81)
(el interruptor de la ventanilla del conductor solo funciona pulsandolo a tope)
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 D
Component: RADIO SON 0004
Coding: 00400
Shop #: WSC 00001
1 Fault Found:
00853 - Loudspeaker(s): Rear
36-10 - Open Circuit - Intermittent
(ni idea, que yo sepa se escuchan todos los altavoces)
End -------------------------------------------------------
Re: AutoScan en mi Passat 3Bg
Coding: 00002
Shop #: WSC 00028
1 Fault Found:
Tienes que cambiar el sensor de temp. del liqui refrigerante, (cuesta 24€ la pieza)
Coding: 04255
Shop #: WSC 00028
Coding: 17000
Shop #: WSC 03403
2 Faults Found:
Imagino que seran los servos de las compuertas, prueba a borrar los errores.
Coding: 05115
Shop #: WSC 03403
1 Fault Found:
Coding: 00006
Shop #: WSC 03403
1 Fault Found:
El error anterior y este son lo mismo, has tocado el confort?
Coding: 00259
Shop #: WSC 00028
2 Faults Found:
Lo que tu dices, tendras cascados los interruptores (?)
Coding: 00400
Shop #: WSC 00001
1 Fault Found:
Eso puede que sea porque has desenchufado los altavoces traseros, o el ISO, quizá de haber instalado el parrot.
Saludos[/quote]
