Hola a todos, soy novato en todo esto, mi problema es que se me ha encendido la luz de fallo motor y a continuación la del muelle parpadeando, he comprado un cable en Mundodiagnosis, y al pasar el autoscan me aparece esto:
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 T HW: 03L 906 023 S
Component: R4 1.6l TDI H13 9979
Revision: --H13--- Serial number:
Coding: 00114016002400080000
Shop #: WSC 53436 001 1048576
ASAM Dataset: EV_ECM16TDI02103L906023T 003014
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 3777761E8E4D8D3EE2-8062
1 Fault Found:
7347 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [039] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 156514 km
Date: 2021.07.19
Time: 19:18:22
Engine speed: 836.00 /min
Normed load value: 3.1 %
Vehicle speed: 0 km/h
Coolant temperature: 91 °C
Intake air temperature: 47 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.892 V
Unlearning counter according OBD: 40
Particle filter: difference pressure-DIP_PF: 0.00 hPa
Particle filter: offset for differential press.-DIP_PF_AD[0]: 0.00 hPa
Outside air temperature-Ambient temperature: 32.25 °C
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 9.06 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 9.10 g
Air mass: actual value:: 5.60 g/s
Readiness: 0 0 0 0 1
