Me podeis decir que averia tiene,leo 7 pero de que?
Monday,11,April,2011,17:39:14:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1C - VW New Beetle
Scan: 01 02 03 08 15 17 19 22 26 29 35 37 39 46 54 56 75
Mileage: 103400km/64249miles
Address 01: Engine Labels: 038-906-018-AGR.lbl
Part No: 038 906 018 AP
Component: 1,9l R4 EDC 0400SG 2124
Coding: 00002
Shop #: WSC 00321
7 Faults Found:
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 - -
01044 - Control Module Incorrectly Coded
09-00 - Adaptation Limit Surpassed
18048 - Internal Control Module: EEPROM Error
P1640 - 35-00 - -
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
P1570 - 35-00 - -
01282 - Intake Manifold Flap change-over Valve (N239)
31-10 - Open or Short to Ground - Intermittent
17970 - Quantity Adjuster (N146): Upper Limit Reached
P1562 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ESP-F.lbl
Part No: 1J0 907 379 S
Component: ESP 20 CAN V010
Coding: 00241
Shop #: WSC 00066
1 Fault Found:
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: D AIRBAG VW3 SG 0002
Coding: 00068
Shop #: WSC 00066
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1C0-919-xx0.lbl
Part No: 1C0 919 861 A
Component: KOMBI+WEGFAHRS. M73 V23
Coding: 00142
Shop #: WSC 00050
Part No: Ident
Component: Nr. Wegfahrs.:VWZ5Z0X2091024
Ident.-Nr. Wegfahrs.:VWZ5Z0X2091024
No fault code found.
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 5Y Zentral-SG Komf. 0001
Coding: 00257
Shop #: WSC 00066
Part No: 1J2959802C
Component: 5Y Tõrsteuerger. FS0001r
Part No: 1J2959801D
Component: 5Y Tõrsteuerger. BF0001r
7 Faults Found:
01483 - Control Circuit for Rear Lid Remote Unlocking
25-10 - Unknown Switch Condition - Intermittent
01179 - Incorrect Key Programming
35-00 - -
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
28-10 - Short to Plus - Intermittent
01332 - Door Control Module; Passenger Side (J387)
53-10 - Supply Voltage Too Low - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 186
Component: Radio 0001
Coding: 08401
Shop #: WSC 00066
