Hola buenas tardes,
envío un autoscan hecho a un A8, me podeis decir algo de los fallos que aparecen ?, por ejemplo.. qué significado tiene redir fail (supongo fallo de dirreción, vamos que no lo encuentra) en el apartado de engine labels.
me podríais aclarar lo de los labels?, perdonar por tanta preguntita.
Gracias anticipadas y un saludo a todos
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
Mileage: 123930km/77006miles
Address 01: Engine Labels: Redir Fail!
Part No: 4D0 907 558 D
Component: 4,2L V8/4V MOTR AT D01
Coding: 05373
Shop #: WSC 00000
2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: None
Part No: 4D0 907 389
Component: ABS/FDR Allrad D21
Shop #: BB 34440
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4D0 820 043 E
Component: D2-KLIMAVOLLAUTOMAT_D03
Coding: 00180
Shop #: WSC 00000
No fault code found.
VCDS
Self-Diagnosis Log
Wednesday,08,April,2009,18:51:48:26365
Page 2
VIN: 000000000000CHOLO License Plate:
Address 15: Airbags Labels: Redir Fail!
Part No: 4D0 959 655 E
Component: Airbag 7 Audi 030B
Coding: 00225
Shop #: WSC 02324
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 4D0-919-033-MYW.lbl
Part No: 4D0 919 033 T
Component: D2-KOMBIINSTRUMENT D42
Coding: 16083
Shop #: WSC 00000
1 Fault Found:
01402 - Data Wiring from Navigation System
27-10 - Implausible Signal - Intermittent
Address 25: Immobilizer Labels: None
Part No: 4B0 953 234
Component: IMMO AUZ9Z0V7003943 D02
Coding: 00000
Shop #: WSC 00000
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257
Component: ZV-Pumpe, DWA, Funk D03
Coding: 13130
Shop #: WSC 23112
3 Faults Found:
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
VCDS
Self-Diagnosis Log
Page 3
Address 45: Inter. Monitor Labels: Redir Fail!
Part No: 8L0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER X010
Coding: 00008
Shop #: WSC 00000
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186
Component: Radio 0001
Coding: 00117
Shop #: WSC 00000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 AB
Component: AG5 01L 4.2l4V A8RdW D05
Coding: 00001
Shop #: WSC 00000
