17978 - Engine Start Blocked by Inmobilizer
Hola a todos llevo un tiempo por aqui leyendo y aprendiendo gracias a vosotros he dejado mi leon FR en plena forma pero ahora un vecino mio tiene un Audi A6 que no le arrranca y le aparece este fallo en el modulo 01 del vag com.
Os pego el autoscan completo por si acaso:
VAG-COM Version: Release 311.2-N
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 907 401 E
Component: 2.5l/4VT EDC G00AG D41
Coding: 01001
Shop #: WSC 02325
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
01375 - Valves for Engine Mounting: Stage 1
38-00 - Output won't Switch or Short to B+
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 4B0 927 156 B
Component: AG5 01V 2.5lTDI RdW 8915
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 H
Component: ABS/ASR 5.3 FRONT D10
Coding: 00011
Shop #: WSC 02325
No fault code found.
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 F
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 919 880 G
Component: C5-KOMBIINSTR. VDO D03
Coding: 00045
Shop #: WSC 00050
IMMO-IDENTNR: AUZ7Z0W0463742
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 A
Component: Zentralverriegelung D30
Coding: 04672
Shop #: WSC 02325
3 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal to Low - Intermittent
01570 - Turn-Off Delay: Terminal 15
29-10 - Short to Ground - Intermittent
01561 - Left Rear Door
61-00 - Won't De-Safe
End -------------------------------------------------------
La mayoria los he borrado pero el 19978 no se va ni a tiros.
Investigando mucho en el wiki de [Only registered and activated users can see links. Click Here To Register...] he visto que en el canal 22 de measuring blocks del inmo (instruments en este caso) te da informacion y leyendolo estos son los valores que da:
Group 22:
Field 1 (Engine Start Permitted): 0 = No. Key is not or matched or incorrectly matched or the Engine Control Module is incorrectly adapted or malfunctioning
Field 2 (ECU Responding): 0 = No. It will not be possible to match the Immo to the ECU at this time
Field 3 (Key condition OK): 1 = Yes. A legitimate transponder code could be read (whether it was authorized or not)
Field 4 (Number of adapted keys): 1
Group 23:
Field 1 (Variable Code Matched): 1 = Yes.
Field 2 (Transponder Status): 0. Transponder in key is not locked. Key has not yet been adapted to Instrument Cluster
Field 3 (Fixed Code Authorized): 1 = Yes
Field 4 (Immobilizer Status): n/a
También he de decir que el coche no arranca para nada, no es que arranque y se pare, directamente no arranca. Alguna idea de que hacer? Lo que me mosquea es el ecu responding ese que de 0
Gracias.
