Duda con datos del autoscan
Muy buenas, adquirí hace poco un vagcom 17.1.3 en autodig (aliexpress) por ahora creo que el cable va bien. Mi coche un seat altea xl 1.6 CAYC del 2013 y le hice nada mas adquirir el cable un autoscan, dandome los siguientes valores
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LG HW: 03L 906 023 KL
Component: 1,6l R4 CR td H43 9968
Revision: --H43--- Serial number:
Coding: 00114036032401080000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM16TDI02103L906023LG 003008
ROD: EV_ECM16TDI02103L906023NR.rod
VCID: 76E43D9AC95C7DF1C3-8022
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 213F4012092300FE841102E890210051350000
Shop #: WSC 04941 000 00000
VCID: 7DF622B6E46A2EA982-8028
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 T HW: 5P0 907 044 T
Component: Climatronic H19 0909
Revision: 00001001
Coding: 0000000003
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 418E9E46D0128A49A6-8014
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 S HW: 1K0 937 086 S
Component: BCM PQ35 M+ 111 0709
Revision: AC111709
Coding: 46180A3C8025B0E04288008095008104425118A8427D81605C 80C7000041
VCID: 40889B42D3188341A9-8014
Subsystem 1 - Part No: 5P0 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 28111 26 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Subsystem 3 - Part No: 5P0 951 171 C
Component: Innenraumuebe 009 4865
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5P0 919 475 B HW: 8P0 919 475 M
Component: PARKHILFE 4K H08 0008
Revision: -------- Serial number: 36861233600824
Coding: 000002
VCID: 3A7CE9AAB5C4D991E7-806E
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: S7 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2YT75/
Coding: 0021303
VCID: 3D76E2B664EAEEA9C2-8068
Subsystem 1 - Serial number: 6332MSME725167403
Subsystem 2 - Serial number: 6342MSME74250126%
Subsystem 3 - Serial number: 6351HSME2E663147A
Subsystem 4 - Serial number: 6361HSME2E660B7AO
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20121214200634
Coding: 108A140002
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWSXS.rod
VCID: 79FE36A6F8421289AE-802C
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0103
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1P0 920 850 N HW: 1P0 920 850 N
Component: KOMBI H03 0705
Serial number: 00000000000000
Coding: 110B01
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 377AF09E8ED6C4F918-8062
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AG HW: 7N0 907 530 AG
Component: J533 Gateway H53 1634
Revision: H53 Serial number: 081212F1002697
Coding: 352202
VCID: 75E63A96DC5A76E9CA-8020
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0705
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADC19EA8DE4A91157-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 6J0 035 342 F HW: 6J0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664002053
Coding: 020100
VCID: 275A20DE5676547988-8072
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0505
Revision: 12110009 Serial number: 0005744762
Coding: 0210B0
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 6DD612F6BC0ABE2932-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 D HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1501
Serial number: 00000007339177
Coding: 000090
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 65 3305
Revision: 00H22000
VCID: 377AF09E46D6C4F918-8062
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0505
Revision: 14110009 Serial number: 0005772862
Coding: 0210B0
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 6ED415FAB10C45310B-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 D HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1501
Serial number: 00000007346097
Coding: 000090
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5P0 035 186 B HW: 5P0 035 186 B
Component: Media2.0 004 0082
Revision: 01000001 Serial number: SEZ1Z3M5319742
Coding: 00040400040000
VCID: 2E54D5FA798C05314B-807A
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AG
Component: Batt.regelung H53 1634
Coding: 030F185A
VCID: 71EE0E86A8325AC916-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000001490792516
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663746878
Coding: 0510000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A7CE9AABDC4D991E7-806E
End-------------------------(Elapsed Time: 03:15)--------------------------
Los siguientes modulos no me aparecen en el menu de los instalados
sin embargo al principio me aparece statuos OK 0000. Esto es porque ¿en mi coche esto modulos estan incluidos dentro de otros?
