VCDS Windows Based VAG/VAS Emulator VCDS Version: Release 908.0 Data version: 20090911
Dealer/Shop Name: Workshop Code: 000 00000
Self-Diagnosis Log Wednesday,08,June,2011,19:17:47:13314
VIN: TMBEH21Z572151003 License Plate: Mileage: Repair Order:
17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 VIN: TMBEH21Z572151003 Mileage: 38410km/23866miles 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 61-Battery Regul. -- Status: Cannot be reached 1100 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 Chassis Type: 1Z - Skoda Octavia II Scan: Auto-detect Chassis Type: 1Z - Skoda Octavia II Scan: Auto-detect Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 61 62 72
01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 61-Battery Regul. -- Status: Cannot be reached 1100 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000
VCDS Self-Diagnosis Log Wednesday,08,June,2011,19:17:48:13314 Page 2
Address 01: Engine Labels: Redir Fail! Part No SW: 03G 906 018 HB HW: 03G 906 018 EB Component: R4 2.0l PPD1.2 2148 Revision: --H42--- Serial number: SKZ7Z0G4158563 Coding: 0000072 Shop #: WSC 22143 282 89243
No fault code found. Readiness: N/A
-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0006786 Shop #: WSC 73430 790 00000
-------------------------------------------------------------------------------Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 M HW: 1Z0 907 044 M Component: ClimatronicPQ35 110 0400 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000
1 Fault Found: 00819 - High Pressure Sensor (G65) 009 - Open or Short to Ground
-------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE Component: Bordnetz-SG H52 2002 Revision: 00H52000 Serial number: 00000004851111 Coding: 21020E111004140000110D000000000000097F065C0000 Shop #: WSC 73430 790 00000
Part No: 1Z1 955 119 C Component: Wischer 130407 022 0601 Coding: 00055223 Shop #: WSC 73430
VCDS Self-Diagnosis Log Wednesday,08,June,2011,19:17:48:13314 Page 3
Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q2 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD15E4PC Coding: 0020786 Shop #: WSC 73430 790 00000
-------------------------------------------------------------------------------Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP Component: Lenksäulenmodul 036 0070 Coding: 0000012 Shop #: WSC 73430 790 00000
-------------------------------------------------------------------------------Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 842 E HW: 1Z0 920 842 E Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4158563 Coding: 0007101 Shop #: WSC 02143 282 89243
VCDS Self-Diagnosis Log Wednesday,08,June,2011,19:17:48:13314 Page 4
Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 AC HW: 1K0 907 951 Component: J533 Gateway H17 0220 Revision: H17 Serial number: 0221J084250029 Coding: E9817F06400202041300 Shop #: WSC 01687 666 30027
2 Faults Found: 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 7 Mileage: 38412 km Time Indication: 0 Date: 2000.00.00 Time: 19:00:15
03406 - Control Module for Battery Monitoring 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 223 Mileage: 38412 km Time Indication: 0 Date: 2000.00.00 Time: 19:01:15
-------------------------------------------------------------------------------Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl Part No SW: 1Z0 920 842 E HW: 1Z0 920 842 E Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4158563 Shop #: WSC 00000 000 00000
VCDS Self-Diagnosis Log Wednesday,08,June,2011,19:17:48:13314 Page 5
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl Part No SW: 1Z0 035 680 A HW: 1Z0 035 680 A Component: RNS-MID H04 1004 Revision: AB001001 Serial number: SKZ6Z7H5119043 Coding: 0C0004000001000000 Shop #: WSC 73430 790 00000 ASAM Dataset: ------------------------- ------
1 Fault Found: 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 223 Mileage: 38412 km Time Indication: 0 Date: 2000.00.00 Time: 18:35:05
-------------------------------------------------------------------------------Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 005 0953 Coding: 0000244 Shop #: WSC 73430 790 00000
-------------------------------------------------------------------------------Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K1 909 144 L Component: EPS_ZFLS Kl.074 H07 1806 Shop #: WSC 73430 000 90108
VCDS Self-Diagnosis Log Wednesday,08,June,2011,19:17:48:13314 Page 6
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 80801A085283007F3F04850500084F01807C00 Shop #: WSC 73430 790 00000
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
-------------------------------------------------------------------------------Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 005 0953 Coding: 0000244 Shop #: WSC 73430 790 00000
-------------------------------------------------------------------------------Address 55: Xenon Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000007 Shop #: WSC 73430 790 00000
VCDS Self-Diagnosis Log Wednesday,08,June,2011,19:17:48:13314 Page 7
Address 56: Radio (J0506) Labels: 1T0-035-680.lbl Part No SW: 1Z0 035 680 A HW: 1Z0 035 680 A Component: RNS-MID H04 1004 Revision: AB001001 Serial number: SKZ6Z7H5119043 Coding: 0C0004000001000000 Shop #: WSC 73430 790 00000 ASAM Dataset: ------------------------- ------
VCDS Self-Diagnosis Log Wednesday,08,June,2011,19:17:48:13314 Page 8
Address 61: Battery Regul. (J840) Labels: None Part No SW: 1K0 907 534 HW: 1K0 907 951 Component: Batt.regelung H17 0220 Revision: -------- Serial number: 0221J084250029 Coding: 03030864 Shop #: WSC 00000 000 00000
3 Faults Found: 02071 - Local Databus 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 223 Mileage: 38412 km Time Indication: 0 Date: 2000.00.00 Time: 19:10:48
02252 - Generator 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 223 Mileage: 38412 km Time Indication: 0 Date: 2000.00.00 Time: 19:10:48
00458 - Control Module for Battery Monitoring (J367) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 223 Mileage: 38412 km Time Indication: 0 Date: 2000.00.00 Time: 19:10:48
VCDS Self-Diagnosis Log Wednesday,08,June,2011,19:17:48:13314 Page 9
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 005 0907 Coding: 0000144 Shop #: WSC 73430 790 1012544
-------------------------------------------------------------------------------Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 005 0907 Coding: 0000144 Shop #: WSC 73430 790 1012544
