Hola tengo un amigo que no le funciona los limpia parabrisas delanteros, tiene un seat leon del 2005, ayer le hize un autocan y me sale 3 en el canal 9,mi pregunta es podria estar mal la centralita 3C0937049D? a ver si alguien me podria hechar una mano gracias.
Tuesday,28,October,2008,19:25:36:55371
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ6R045171 Mileage: 54020km/33566miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 03G 906 016 AK HW: 028 101 188 4
Component: R4 1,9L EDC 0000SG 7621
Coding: 0050071
Shop #: WSC 06441
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.LBL
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06441
Address 08: Auto HVAC Labels: 1K0-820-047.LBL
Part No: 5P0 820 047 K
Component: Climatic PQ35 011 0201
Address 09: Cent. Elect. Labels: 3C0-937-049.LBL
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Coding: 40880F2F00041000001D00000000000000007B075C
Shop #: WSC 06441
Component: Fehler Lin-Slave 01
Component: Fehler Lin-Slave 02
3 Faults Found:
02071 - Local Databus
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 85
Mileage: 54026 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.65 V
ON
ON
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 85
Mileage: 54026 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.65 V
ON
ON
OFF
OFF
OFF
00153 - Left Windshield Wiper Motor (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 85
Mileage: 54026 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.65 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.LBL
Part No SW: 3C0 909 605 H HW: 3C0 909 605 H
Component: R2 AIRBAG VW8 027 2521
Coding: 0021042
Shop #: WSC 06441
Address 16: Steering wheel Labels: 1K0-953-549.LBL
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0002012
Shop #: WSC 06441
Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.LBL
Part No: 1P0 920 823 G
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 00176
Address 19: CAN Gateway Labels: 1K0-907-530.LBL
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Coding: 3D3F0340070202
Shop #: WSC 06441
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 123
Mileage: 54015 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:08
Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.LBL
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2451
Coding: 0000176
Shop #: WSC 06441
Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC090005054C4F090004CC
Shop #: WSC 06441
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.LBL
Part No: 1T0 959 702 C
Coding: 0000176
Shop #: WSC 06441
Address 56: Radio Labels: 1K0-035-1xx-56.LBL
Part No: 1P1 035 152
Component: Radio BNO 0035
Coding: 0040400
Shop #: WSC 06441
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN2.LBL
Part No: 1K0 959 703 G
Component: Tuer-SG 021 2420
Coding: 0000144
Shop #: WSC 06441
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.LBL
Part No: 1K0 959 704 G
Coding: 0000144
Shop #: WSC 06441
End --------------------------------------------------------------------------------------------------
