A ver quien me puede echar una mano con una diagnosis que he pasado en un A4 2.5 V6.
El tema es saber, en qué fecha y Km saltó la avería que marca en el módulo 17 por el tema del sensor de aceite..
VCDS
Windows Based VAG/VAS Emulator
VCDS Version: Release 10.6.4 Data version: 20110418
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Wednesday,27,June,2012,12:48:52:10074
VIN: WAUZZZ8E42A19xxxx License Plate:
Mileage: 317950km-197564mi Repair Order:
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: WAUZZZ8E42A19xxxx Mileage: 317950km/197564miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8E0 907 401 D
Component: 2.5L V6 TDI 0000AG 0006
Coding: 02016
Shop #: WSC 63351
VCID: 2647F2ABE877
Part No: 00004059
Component: 130 106LC150_1.V77685261191
WAUZZZ8E42A19xxxx AUZ6Z0A0297531
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 L
Component: AG5 01V 2.5lTDI RdW 2121
Coding: 00001
Shop #: WSC 00000
VCID: 37792FEF3FDD
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04457
Shop #: WSC 06435
VCID: 2647F2ABE877
VCDS
Self-Diagnosis Log
Page 2
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 63351
VCID: DEB71A4B70A7
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 4001
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: F4E358E3EE2B
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
VCID: 366722EB38D7
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 G
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 01100
Shop #: WSC 11111
VCID: 285BFC93E263
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
01311 - Information Data Bus
80-00 - Single-Wire Operation
VCDS
Self-Diagnosis Log
Page 3
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 00000
VCID: EBD1439FB315
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
VCID: 040388233E8B
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186
Component: concert II GRO 0007
Coding: 00003
Shop #: WSC 63351
VCID: E4C328A35ECB
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
01305 - Databus for Infotainment
¿ se puede llegar a sacar de alguna manera ??,
En la actualidad, el coche marca 1 Km más en el marcador, de los que salen en la ficha. Desde el golpe, se supone que no ha andado nada hasta la fecha..
No se con certeza el porqué de la diferencia de ese km. El coche recorrió muy pocos metros desde el golpe.
