Hola acabo de hacerle otro autoscan, me sale estos fallos, lo del arabol de levas hacia tiempo que no me salia, que puedo hacer para saber si esta roto? o sera el sensor que esta sucio? y lo del CLIMATRONIC no lo entiendo
un saludo
Código:AG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 HH
Component: 1,9l R4 EDC 0400SG 1491
Coding: 00002
Shop #: WSC 07395
WVWZZZ1JZ2W581820 VWZ6Z0A3866666
1 Fault Found:
19463 - Camshaft Position Sensor (G40): No Signal
P3007 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019970
Shop #: WSC 01271
No fault code found.
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 01271
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15 -------------------------------------------------------
Controller: 1C0 909 605 F
Component: 02 AIRBAG VW61 0101 0001
Coding: 12338
Shop #: WSC 01271
Address 17 -------------------------------------------------------
Controller: 1J0 920 826 CX
Component: KOMBI+WEGFAHRS. RB8 V18
Coding: 23114
Shop #: WSC 03334
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 03334
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 1C Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 01271
2 Faults Found:
00912 - Window Regulator Switch: Front Left (E40)
27-10 - Implausible Signal - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
End -------------------------------------------------------
