Hola buenas, soy nuevo a ver si me podéis ayudar. Hace unos seis meses note una pequeña perdida de potencia, pero iba bien.
El caso es que hace unas 3 semanas se me encendió el testigo de fallo de motor y ayer le pude meter el VAG-COM y me dio lo siguiente:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWZZZ1JZ2P040515 Mileage: 199570km/124007miles
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 00028
VCID: 6DD12F3F276425764F5-5072
WVWZZZ1JZ2P040515 VWZ7Z0A4019925
5 Faults Found:
17608 - Boost Pressure Control Valve (N249)
P1200 - 35-00 - Mechanical Malfunction
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 00028 000 00000
VCID: 2C57E23B8CFEEC7E18B-5072
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 00028
VCID: 2149030FAB3C3116BBD-5072
2 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-10 - Faulty - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 02 AIRBAG VW6 0101 0004
Coding: 12338
Shop #: WSC 00028
VCID: 3A7BD46326AA42CE9A7-5000
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 826 A
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 05122
Shop #: WSC 00000
VCID: 275D1D17C518CF26F59-5000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 1E Komfortgerát HLO 0003
Coding: 00065
Shop #: WSC 00028
VCID: 3663C05312B2A6AE7EF-4A3A
Subsystem 1 - Part No: 1C1959801A
Component: 1E Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802A
Component: 1E Tõrsteuer.BF KLO 0002
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00933 - Electric Window Motor; Passenger Side (V148)
62-10 - No or Incorrect Adjustment - Intermittent
Address 55: Xenon Range Labels: 1J0-941-651.lbl
Part No: 1J0 941 651
Component: Leuchtweitenregel. V07
Coding: 00001
Shop #: WSC 00028
VCID: E5C1D71F7F949D36875-4C30
No entiendo mucho, pero según sale hay uno de los fallos es un problema de combustión en un cilindro. No se si me tengo que preocupar en general de lo demás que se algo grave.
A ver si me podéis ayudar, Un saludo.
