Friday,05,August,2016,20:47:10:21468VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.4.1
Data version: 20160216
Chassis Type: 1T (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 3C 42 44 52 55 5F 65 6D A5
VIN: WVGZZZ1TZ
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-DFHA) Labels: None
Part No SW: 04L 906 026 GT HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3019
Revision: B4H24---
Coding: 011D001203641D082000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01140L906026GT 004002
ROD: N/A
VCID: 020C13A3955CCD2E68-8056
Unsupported vehicle.
No ASAM data for: "EV_ECM20TDI01140L906026GT" ()
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 042 F HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4902
Revision: 06354004 Serial number: TFK01606151754
Coding: 0014
ASAM Dataset: EV_TCDMQ250021 001001
ROD: N/A
VCID: 1C304DDB17F81BDE82-8048
No ASAM data for: "EV_TCDMQ250021" ()
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 61726000000851
Coding: 0CEA6AA034210B6E4777360841C84930562CD0E26C82927518 62F00842A202
ASAM Dataset: EV_BrakeU1DSContiMK100IPB 035019
ROD: N/A
VCID: 7BF26E47F2B6BCE62B-802E
No ASAM data for: "EV_BrakeU1DSContiMK100IPB" ()
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BP HW: 5G0 907 044 BP
Component: Climatronic H04 1601
Revision: 00001K10
Coding: 0802012420011001110510000010102A
ASAM Dataset: EV_ACClima
HBBVW37X 006142
ROD: N/A
VCID: 76E47F73C994E18E54-8022
No ASAM data for: "EV_ACClimaHBBVW37X" ()
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: BCM PQ37BOSCH 028 0162
Revision: -------- Serial number: 8658200616019L
Coding: 00D01E46C2411AF357C4401800041328108000000000000000 0000000000
ASAM Dataset: EV_
ObdyContrModul1UDSBosc 015002
ROD: N/A
VCID: 030216A78A46C42663-8056
Subsystem 1 - Part No SW: 5TB 955 119 A HW: 5TB 955 119
Component: WWS 160513 043 0608
Serial number: 160528222559
Coding: 0E4DDD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y16M06D25H05M12S27
Coding: 90A8DD
No ASAM data for: "EV_ObdyContrModul1UDSBosc" ()
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39391617408998
Coding: 0071155811
ASAM Dataset: EV_EPVHA18AU3700000 002026
ROD: N/A
VCID: 4480D5BBCFC8031E1A-8010
No ASAM data for: "EV_EPVHA18AU3700000" ()
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 320467D251FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: N/A
VCID: 3460857B9F68B39EAA-8060
ACBCOSCHVW48X" ()
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AE HW: 5Q0 959 655 AE
Component: AirbagVW21 005 0130
Serial number: 003NSR1VYY5E
Coding: 98CCC0C00C0000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: N/A
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 5TB857705E0176Q00144
Coding: 80000D
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 5TB857706E0176Q00939
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 306 16
Component: SideSensor_Df 001 0887
Serial number: 357000000005D6342C1I
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 002 306 16
Component: SideSensor_Pf 001 0887
Serial number: 35800000000EC6342C1R
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 480 412 106 16
Component: SideSensor_Dr 003 0189
Serial number: 351001A05FCC4994BD8-
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 480 412 106 16
Component: SideSensor_Pr 003 0189
Serial number: 352001A051D5DA245C9E
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 480 402 106 16
Component: FrontSensor_D 000 6149
Serial number: 35500019F20E2704124V
Coding: 2D2D2D
Subsystem 8 - Part No SW: ----------- HW: 480 402 406 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001A120E2703753O
Coding: 2D2D2D
Subsystem 9 - Part No SW: ----------- HW: 480 402 406 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A120E2704713M
Coding: 2D2D2D
Subsystem 10 - Part No SW: ----------- HW: 480 402 406 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001A120E2704163D
Coding: 2D2D2D
Subsystem 11 - Part No SW: ----------- HW: 480 001 406 16
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000C379D0C1B
Coding: 2D2D2D
Subsystem 12 - Part No SW: ----------- HW: 480 001 406 16
Component: PedPSensor_P2 001 0887
Serial number: I0N000000008479D0C19
Coding: 2D2D2D
No ASAM data for: "EV_AirbaVW20SMEVW37X" ()
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GK HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 19061604400788
Coding: 0C10
ASAM Dataset: EV_SMLSKOLMQB 020002
ROD: N/A
VCID: 050608BF8472FA164D-8050
No ASAM data for: "EV_SMLSKOLMQB" ()
Address 17: Instruments (J285) Labels: None
Part No SW: 5TA 920 751 A HW: 5TA 920 751 A
Component: KOMBI 304 8311
Coding: 07A401886E8C000801886B0F1400000000000000
ASAM Dataset: EV_DashboardVDDMQBAB 009051
ROD: N/A
VCID: 4382D6A7CAC6042623-8016
DashObardVDDMQBAB" ()
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005053410
Coding: 0B0100041F087300FB00025E1C0F0001000105000000000000 0000000000
ASAM Dataset: EV_GatewLear 013020
ROD: N/A
VCID: 7CF06D5BF7B8BBDE22-8028
Subsystem 2 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B
Component: E221__MFL-TAT H06 0023
Serial number: 1721620561401859AS2B
Coding: 2D0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Component: J367-BDMHella H10 9070
Serial number: 8724100404
Subsystem 4 - Part No SW: 5Q0 907 155 D HW: 5Q0 907 155 D
Component: WECHSELRICHTE H55 0033
Serial number: 0241171
AgtewLear" ()
Address 3C: Lane Change (J769) Labels: None
Part No SW: 3Q0 907 566 C HW: 3Q0 907 566
Component: MRR1Rear H16 0310
Revision: --------
Coding: 04C002
VCID: 3878B14B830057FE86-806C
No ASAM data for: "Unknown" ()
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 080616EF72319A
Coding: 003B8320D200048000001000
ASAM Dataset: EV_DUCDriveSideEWMAXKLO 006003
ROD: N/A
No ASAM data for: "EV_DUCDriveSideEWMAXKLO" ()
Address 44: Steering Assist (J500) Labels: 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000881667
Coding: 01000011005001
ASAM Dataset: EV_SteerAssivSWBSMQBA 008028
ROD: N/A
VCID: 3D76A05FAC2272D655-8068
No ASAM data for: "EV_SteerAssivSWBSMQBA" ()
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 070616EF515665
Coding: 003B8120DE00048000801000
ASAM Dataset: EV_DCUPasseSideWEMAXKLO 006003
ROD: N/A
VCID: 428CD3A3D5DC0D2E28-8016
No ASAM data for: "EV_DCUPasseSideWEMAXKLO" ()
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0051
Revision: -------- Serial number: --------------
Coding: 078A02104B210001
ASAM Dataset: EV_HeadlRegulFASMQBMAX 001001
ROD: N/A
VCID: 418EDCAFD0DA163631-8014
Subsystem 2 - Part No SW: ----------- HW: -----------
Component: LeiMo links --- ----
Coding: 000000
Subsystem 3 - Part No SW: ----------- HW: -----------
Component: LeiMo rechts --- ----
Coding: 000000
No ASAM data for: "EV_HeadlRegulFASMQBMAX" ()
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 3G0 035 043 D HW: 3G0 035 043
Component: MU-H-N-EU H51 0687
Serial number: A683F0GS033412
Coding: 02730801FF00000051110001000808001F0100D4012001009F
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: N/A
VCID: 1D3640DF0CE212D675-8048
Subsystem 2 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL01LU1
Component: ------------- --- ----
Serial number: --------------------
Subsystem 4 - Part No SW: V03 959 800 QP HW: -----------
Component: ECE 2016/2017 --- 0153
Subsystem 7 - Part No SW: ----------- HW: -----------
Subsystem 8 - Part No SW: ----------- HW: -----------
Subsystem 9 - Part No SW: ----------- HW: -----------
Subsystem 12 - Part No SW: ----------- HW: -----------
Subsystem 13 - Part No SW: ----------- HW: -----------
Subsystem 14 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1013
No ASAM data for: "EV_MUHig4CGen2HBAS" ()
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000023039
ASAM Dataset: EV_RDKBEUR30 006001
ROD: N/A
No ASAM data for: "EV_RDKBEUR30" ()
Address 6D: Trunk Elect. (J605) Labels: None
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30788123200000
Coding: 0300
ASAM Dataset: EV_DeckLidCOTNIAU736 001012
ROD: N/A
VCID: 3F8ADA57A62E60C647-806A
No ASAM data for: "EV_DeckLidCOTNIAU736" ()
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 22061611P20565
Coding: 0003070800000401002223468050A10098000E300040
ASAM Dataset: EV_MFKBoshcMQBB 001001
ROD: N/A
VCID: 3A7CAB43BD0C45EE70-806E
No ASAM data for: "EV_MFKBoshcMQBB" ()
End-------------------------(Elapsed Time: 05:39)--------------------------
