Piloto Airbag encendido en VW UP
Hola a todos!
en el VW Up de mi mujer hace un tiempo que se enciende la luz de averia airbag, le paso el soft y reseteo alarmas pero en pocas horas vuelve a salir.
Aquí dejo el diagnósitco a ver si alguien me puede echar una mano, muchas gracias.
Tuesday,02,May,2017,20:27:22:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
VIN: WVWZZZAAZCD006051 License Plate:
Mileage: 40530km-25184mi Repair Order:
Chassis Type: AA (6N0)
Scan: 01 03 09 13 15 17 19 25 44 56 AD
VIN: WVWZZZAAZCD006051 Mileage: 40530km-25184miles
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
AD-Brake Sensors -- Status: Malfunction 0010
Address 01: Engine (------CHYB) Labels: 04C-906-020-CHY.clb
Part No SW: 04C 906 020 A HW: 04C 907 309
Component: 1.0l R3 MPI H01 2423
Revision: U7H01--- Serial number:
Coding: 00110012020400000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM10MPI01104C906020A 001010
ROD: EV_ECM10MPI01104C906020.rod
VCID: 193E16261802F2890E-804C
1 Fault Found:
5649 - Throttle Control
P3078 00 [101] - Airflow at Idle too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 40471 km
Date: 2017.04.29
Time: 18:15:30
Engine speed: 3014.00 /min
Normed load value: 13.7 %
Vehicle speed: 81 km/h
Coolant temperature: 87 °C
Intake air temperature: 33 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.418 V
Unlearning counter according OBD: 40
Fuel level: 35.00 l
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 C HW: 1S0 614 517 C
Component: EBC 460 ESP H08 0004
Serial number: 0021868
Coding: 12BF247189AD02F748FA24FA91AA404058B000
ASAM Dataset: EV_Brake1UDSESP 015024
ROD: EV_Brake1UDSESP.rod
VCID: 2F6AC8FE76860C3940-807A
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 1S0-937-08x-09.clb
Part No SW: 1S0 937 086 HW: 1S0 937 086
Component: PQ25 BCM H57 0511
Revision: -0------ Serial number: 1009068800
Coding: 24B0290000010000000000042C282CD00040400C6002000020 0000420100
VCID: 75E63A96DC5A76E9CA-8020
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 7
Reset counter: 239
Mileage: 40490 km
Time Indication: 0
Date: 2017.05.01
Time: 12:03:24
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 1S0 959 655 HW: 1S0 959 655
Component: VW10Airbag005 H02 0005
Revision: -------- Serial number: 003G3000BVK+
Coding: 000000000000000000000000000000003035
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 7BF22CAEF27E2099BC-802E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40590SM2O5OA-
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB404P0SM2O40AR
Crash sensor for front airbag: driver side:
Serial number: 3555NRB405V0TO4MB0PJ
1 Fault Found:
9445417 - Key switch for deactivation of passenger-side airbag
B1020 29 [136] - Signal Implausible
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 40419 km
Date: 2017.04.29
Time: 08:11:38
Address 17: Instruments (J285) Labels: 1Sx-920-xxx-17.clb
Part No SW: 1S0 920 860 B HW: 1S0 920 860 B
Component: KOMBI H08 0019
Revision: X0008003 Serial number: 00000000000000
Coding: 114200
ASAM Dataset: EV_KombiUDSMM9RM10 A04708
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 1S0 937 086
Component: GW-K-CAN TP20 H57 0511
Revision: -0------
Coding: 001000
Shop #: WSC 78129 152 411206
VCID: 70E80B82A33853C119-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1S0 920 860 B
Component: IMMO H08 0019
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW01.rod
VCID: 6ADC19EA8DE4A91157-803E
Address 44: Steering Assist (J792) Labels: 1Sx-909-144-44.clb
Part No SW: 1S1 909 144 F HW: 1S1 909 144
Component: EPS_ECU H15 1502
Coding: 0001000101000000
ASAM Dataset: EV_SteerAssisNSK 008004
ROD: EV_SteerAssisNSK_006.rod
VCID: 3664FD9A89DC3DF103-8062
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1S0 035 156 A HW: 1S0 035 156 A
Component: Radio H35 0045
Revision: R0000000 Serial number: VWASASL2702653
Coding: 0000020801
VCID: 295E26E6406262099E-807C
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 HW: 1S0 907 201
Component: CV-SENSOR H05 0450
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 67DA60DE9EF6947948-8032
1 Fault Found:
0004 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 31
Reset counter: 239
Mileage: 40293 km
Date: 2017.04.24
Time: 06:59:53
End-------------------------(Elapsed Time: 01:48)--------------------------
