Mi primer autotest! 3 Erorres, añado LOG!
Acabo de realizar mi primer test y me da estos errores, ¿que puede ser?
VCDS Version: Release 805.0
Data version: 20080625
Friday,27,November,2009,12:00:26:26365
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: ********************* Mileage: 124110km/77118miles
15-Airbags -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 B HW: 028 101 147 8
Component: R4 1,9L EDC 0000SG 5645
Revision: 12345678 Serial number: VWZ7Z0D9790679
Coding: 0000071
Shop #: WSC 00046 000 00000
1 Fault Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 42.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 11000100
Temperature: 16.2°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0021121
Shop #: WSC 00046 412 08192
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 L HW: 1K0 937 049 L*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000001162652
Coding: A5890F0600041800001400001400000000
Shop #: WSC 00046 412 63078
Part No: 1K1 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00046
1 Fault Found:
00061 - Footwell Lights
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: 01 AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0C5EG%
Coding: 0012337
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0002012
Shop #: WSC 00046 412 442368
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0030
Part No: 1K0 920 860 L
Component: KOMBIINSTRUMENT VDD 3354
Coding: 0001101
Shop #: WSC 07383 244 67381
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 21001044052562
Coding: 3D3F0B40070002
Shop #: WSC 00046 412 434176
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3354
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0112
Coding: 0000052
Shop #: WSC 00046 412 630784
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.2 1301
Address 46: Central Conv. Labels: 1K0-959-433-46.lbl
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 58E802087F2D8404084F0100
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 J
Component: Radio GR0 0014
Revision: 0001002S Serial number: VWZ2Z2D1543195
Coding: 0020200
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Component: Tuersteuergeraet 06 0202
Coding: 0000016
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
End ------------------------------------------------
