Primero que nada muchas gracias por contestar, Jurjito le pongo el código que me propones y me sale el mismo error de todas maneras te pongo el scanner entero por si hay algun otro fallo en otro sitio.Cita:
Thursday,05,May,2011,08:46:16:46862
VCDS Version: Release 10.6.0
Data version: 20090830
Chassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 5D 62 72 77
VIN: WVWZZZ3CZ8E181464 Mileage: 55800km/34672miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5D-Operations -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 018 FG HW: 03G 906 018 FG
Component: R4 2.0l PPD1.5 G 0907
Revision: --H55--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 05314 000 00000
VCID: 6FE6D1E241C71A64
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: None
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000785147930
Coding: 0000267
Shop #: WSC 05311 000 00000
VCID: 1F46E122F1E7CAE4
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CR HW: 3C0 907 044 CR
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 73EEDD922DEF3E84
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007994364
Coding: E5800F0700041A00470A00000F00000000095D431E00012C00 0000000000
Shop #: WSC 05124 000 00000
VCID: 71E2D79A57F30C94
Part No: 3C1 955 419 A
Component: Wischer 121207 003 0205
Coding: 00046997
Shop #: WSC 05124
Part No: 1K0 955 559 AF
Component: RLS 040208 046 0204
Coding: 00405544
Shop #: WSC 05124
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP1JXLUP
Coding: 0012341
VCID: 3B7E35B2453FB6C4
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AT
Coding: 0000311
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00748 572 86194
VCID: 2648F4C6AEBD1B2C
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P082020D59
Coding: F9807F064026021002
VCID: 234EEDD2DD8FEE04
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 39722FBA4F0384D4
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 1T0 035 680 D HW: 1T0 035 680 C
Component: RNS-MID H41 3810
Revision: AB001001 Serial number: VWZ6Z7K0542417
Coding: 04000440040000002000
Shop #: WSC 00046 412 73728
ASAM Dataset: ------------------------- ------
VCID: 2F6611E281475A64
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000088888124
Coding: 0000245
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.134 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356A238A631B60B4
Address 46: Central Conv. Labels: 3C0-959-433-46.lbl
Component: KSG PQ46 ELV 042 0472
Coding: 19910A0001864E763002151F70088F0B607C01
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000604688123
Coding: 0000244
VCID: 3C7C36AE4031B1FC
Address 53: Parking Brake Labels: 5N0-907-801.lbl
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000339235
Coding: 0000057
VCID: 2952FFFABFA33454
Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
Address 5D: Operations Labels: None
Part No SW: 3C0 035 151 C HW: 3C0 035 151 C
Component: J738 011 0019
Revision: 00011000
VCID: 1834CA3E14C9BDDC
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0308
Revision: 41004101 Serial number: 00000000168177
Coding: 0000208
VCID: 70E4D29E5CF9059C
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0308
Revision: 41004101 Serial number: 00000000191126
Coding: 0000208
1 Fault Found
01334 - Door Control Module; Rear Right (J389)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 192
Mileage: 46725 km
Time Indication: 0
Date: 2010.10.13
Time: 12:42:54
Address 77: Telephone Labels: 3C0-035-730.lbl
Part No SW: 5N0 035 730 HW: 5N0 035 730
Component: Telefon 2510
Revision: 00011000 Serial number: 0000000056015
Coding: 0046241
Shop #: WSC 01223 123 12345
VCID: E5CA33CA133B5034
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 55807 km
Time Indication: 0
Date: 2011.05.06
Time: 08:44:45
