Mirando en el foro oficial de OBDeleven, en las codificaciones del passat B8, únicamente pone que se active el bit 0 en el modulo 44:
Line Assist Activation
Select Control unit 17 (Dashboard)
Control unit Long Coding
Bye 4
Bit 6 Activate
Bye 11
Bit 1 Activate
Select Control unit A5 (front / advance camera)
Bye 0
Bit 0 Activate
Security access
Access Code 20103
Adaptation
Channel - Seçim HCA_On_State
Put emphasis on menu
Channel - Seçim HCA_Warning_intensity
Channel - Seçim BAP_Personalisierung
Put emphasis on not activated
Select the time of engagement
Set adjustment via menu - emphasis on late
Select Personalization spurt holding an assistant to a terminal 15 - channel
Set value to last setting
Select Control unit 44 (power steering)
Bye 0
Bit 0 Aktif
Select Control unit 5F (Informationselektronik)
Adaptation
(49) function -Vehicle list BAP LDW_HCA_0x19
Activate
(21) vehicle menu operation-menu_display_Lane_Departure_Warning
Activate
(23) vehicle menu Bedienung_menu_display_Lane_Departure_Warning_over _threshold_high – channel
Activate
