Gracias Jurjito, mira a ver si me puedes echar una mano con un fallo que me ha salido despues de instalar el media in, al hacer el autoscan esto es lo que me marca:
Sunday,14,November,2010,13:48:56:26365
VCDS Version: Release 805.0
Data version: 20080625
Chassis Type: 1K0
Scan: 01 03 04 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ8P040787 Mileage: 84370km/52425miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 PM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 1136
Revision: --H07--- Serial number: VWX7Z0G83NK1DK
Coding: 0000071
Shop #: WSC 03019 572 93786
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0037505
Shop #: WSC 00028 028 00001
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005124350
Coding: 05090FA700041500471400001400000000097F075C00010C00 0000000000
Part No: 1K1 955 119 E
Component: Wischer 130102 021 0501
Coding: 00038805
Shop #: WSC 00028
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1GJG8N
Coding: 0013111
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000042
Part No SW: 1K0 920 864 B HW: 1K0 920 864 B
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0G83NK1DK
Coding: 0003103
Shop #: WSC 15755 572 75789
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 150907F1002013
Coding: E9807F064006120002
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 1212
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667798619
Coding: 010000
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 1T0 035 680 B HW: 1T0 035 680 B
Component: RNS-MID H11 1200
Revision: AB001001 Serial number: VWZ6Z7J2132039
Coding: 020004000000001000
1 Fault Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 69
Mileage: 84376 km
Time Indication: 0
Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 69
Mileage: 84376 km
Time Indication: 0
¿Sabes a que puede ser debido? me salia otro en la gateway, pero era porque no tenia puesto el media in, lo puse y se quito pero este no se a que se refiere, lo borro y me vuelve a aparecer.
Saludos desde León:ok::ok::ok:
