Bueno gracias jose R , aca dejo un pantallazo de los canales 1 a 24 , recién sacados ,espero sus comentarios , en la semana voy a sacar tapa de válvulas y verifico cableado ,espero sea eso , verán en los datos de abajo que pase el angle syncro de 2.7 a 1.05 y ha mejorado bastante , pero no es digno todavía de un tdi .
Address 01: Engine (03G 906 018 FG)
19:14:41 Group 001: Injection Quantity
800 /min Engine Speed (G28)
5.6 mg/str Injection Quantity
2.6°KW Injection Duration (specified)
89.0°C Coolant Temperature (G62)
19:14:41 Group 002: Idle Speed
0.0 % Accel. Pedal Pos. Sensor 1 (G79)
00001000 Operation Status
19:14:41 Group 003: Exhaust Gas Recirculation (EGR)
802 /min Engine Speed (G28)
399.1 mg/str Exhaust Gas Recirculat. (spec.)
399.1 mg/str Exhaust Gas Recirculat. (actual)
0.0 % Exhaust Gas Recirc. Duty Cycle
Tuesday,01,October,2013,19:17:48:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
19:17:47 Group 004: Unit Injector
799 /min Engine Speed (G28)
2.1 °ATDC Injection Start (specified)
2.5°KW Injection Duration (specified)
1.09° Torsion Value
19:17:47 Group 005: Start Conditions (last Engine Start)
0.0 Nm Starting Torque
255.0 Start Synchronisation
19:17:47 Group 006: Cruise Control System (CCS)
0.0 km/h Vehicle Speed (actual)
00001000 Cruise Control Pedal Monitoring
00000000 Cruise Control Switch Monitoring
Tuesday,01,October,2013,19:19:59:40973
19:19:58 Group 007: Temperatures
80.0°C Fuel Temperature (G81)
40.0°C Intake Air Temperature (G72)
19:19:58 Group 008: Injection Quantity Limitation I (Torque Limitation)
803 /min Engine Speed (G28)
0.0 Nm Torque Request (Driver)
190.0 Nm Torque Limitation
117.0 Nm Smoke Limitation
19:19:58 Group 009: Injection Quantity Limitation II (Torque Limitation)
-992.0 Nm Torque Request (Cruise Control)
1024.0 Nm Transmission Limitiation
117.0 Nm Torque Restriction
19:20:40 Group 010: Charge Pressure Control
401.8 mg/str Mass Air Flow (actual)
856.5 mbar Atmospheric Pressure
858.9 mbar Boost Pressure (actual)
19:20:40 Group 011: Charge Pressure Control
858.8 mbar Boost Pressure (specified)
859.0 mbar Boost Pressure (actual)
80.0 % Charge Pressure Control Duty Cycle
19:20:40 Group 012: Glow Plugs
11111111 Glow Status
0.90 s Pre-Glow Period
14.229 V Supply Voltage (Terminal 30)
Tuesday,01,October,2013,19:21:01:40973
19:21:45 Group 013: Idle Stabilization (Injection Quantity Deviation)
0.97 mg/str Injection Quantity Deviation Cyl. 1
-0.22 mg/str Injection Quantity Deviation Cyl. 2
-1.29 mg/str Injection Quantity Deviation Cyl. 3
0.53 mg/str Injection Quantity Deviation Cyl. 4
19:21:45 Group 014
19:21:45 Group 015: Fuel Consumption
801 /min Engine Speed (G28)
35.6 Nm Engine Torque
0.76 l/h Fuel Consumption
Tuesday,01,October,2013,19:22:18:40973
19:22:17 Group 016: Auxiliary Heating
29.8 % Generator Load
11000011 Shut-Off Status Aux. Heater
252 Heater Element Activation
14.118 V Supply Voltage (Terminal 30)
19:22:17 Group 017: Readiness Code (EOBD)
00000000 EOBD/CARB Mode 01 DATA A
00000110 EOBD/CARB Mode 01 DATA B
10000000 EOBD/CARB Mode 01 DATA C
10000000 EOBD/CARB Mode 01 DATA D
19:22:17 Group 018: Piezo Unit Injector Status
0.0 Injector Status Cylinder 1
999 Injector Status Cylinder 2
0.0 Injector Status Cylinder 3
0.0 Injector Status Cylinder 4
Tuesday,01,October,2013,19:22:49:40973
19:22:47 Group 019
138.75 V Voltage
147.25 V Voltage
139.25 V Voltage
147.00 V Voltage
19:22:47 Group 020: Injection Quantity Limitation (from ABS)
36.1 Nm Engine Torque
1024.0 Nm ASR Limitation
0.0 Nm MSR Limitation
19:22:47 Group 021: CAN-Databus Status (Powertrain)
00000000 Engine Electronics
01000000 Transmission Electronics
00000000 Brake Electronics
00000100 Brake Electronics (ESP)
Tuesday,01,October,2013,19:23:13:40973
19:23:12 Group 022: Shut-Off Status
1 Shut-Off Status Cruise Control
0.0 Switch Monitoring Cruise Control
0.0 Shut-Off Status Charge Pressure
0.0 Shut-Off Status Climate Control
19:23:12 Group 023: Unit Injector Switching Time Deviation
0.22 ms Switch Time Deviat. Cylinder 1
0.24 ms Switch Time Deviat. Cylinder 2
0.22 ms Switch Time Deviat. Cylinder 3
0.23 ms Switch Time Deviat. Cylinder 4
19:23:12 Group 024
812 Count
836 Count
815 Count
858 Count
Tuesday,01,October,2013,19:23:47:40973
