me podeis ayudar no me sale ninguno en rojo pero me salen esos codigos me podeis explicar un poco porfavor un saludo y gracias
Código:VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Engine
Saturday,05,September,2015,19:38:37:62939
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ2P043409 Mileage: 262290km/162979miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 ER
Component: 1,9l R4 EDC 0000SG 1412
Coding: 00005
Shop #: WSC 00028
VCID: 6BD5212719702B46511-49D8
WVWZZZ3BZ2P043409 VWZ7Z0A3753225
1 Fault Found:
17964 - Charge Pressure Control
P1556 - 35-10 - Negative Deviation - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1328
Coding: 04255
Shop #: WSC 00028
VCID: 2541171FBF14DD36C75-5072
2 Faults Found:
00532 - Supply Voltage B+
07-00 - Signal too Low
35-00 - -
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0004
Coding: 17000
Shop #: WSC 00028
VCID: 26431013C212D62ECEF-5000
6 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
35-10 - - - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
01272 - Positioning Motor for Central Flap (V70)
01273 - Fresh Air Blower (V2)
00792 - A/C Pressure Switch (F129)
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 C
Component: 08 AIRBAG VW6 04 0004
Coding: 12344
Shop #: WSC 00028
VCID: 377DCD5715B85FA6659-5072
1 Fault Found:
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 806 A
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05125
Shop #: WSC 08563
VCID: 1F4D05F79D4807E68D9-5000
5 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
00462 - Control Module for Seat Memory; Rear (J522)
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: F0EFB64BB056489EE43-5000
6 Faults Found:
01333 - Door Control Module; Rear Left (J388)
00463 - Control Module for Digital Sound Package (J525)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 0Z Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00028
VCID: 3663C05312B2A6AE7EF-4A9C
Subsystem 1 - Part No: 1C1959801
Component: 0Z Tõrsteuer.FS KLO 0003
Subsystem 2 - Part No: 1C1959802
Component: 0Z Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811
Component: 0Z Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812
Component: 0Z Tõrsteuer.HR 0001
10 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-00 - Supply Voltage Too Low
80-00 - Single-Wire Operation
01331 - Door Control Module; Driver Side (J386)
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
01332 - Door Control Module; Passenger Side (J387)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
01334 - Door Control Module; Rear Right (J389)
00931 - Locking Module for Central Locking; Rear Right (F223)
