bueno encontré esto googleando, eso no está disponible en el 1200, yo puse el 2680 o algo así, pero aparecia siempre alemania y ahora he puesto otro de un tal josi o algo así que es modificado el firmware, en teoría para que funcione todo, y no aparezca en alemania, ya veremos a ver....
A dutch forum says that the 1200 only gives you the 32GB SD and importing POI by SD card
The following are not available
- Voice Control (requires microphone - see note below)
- Speed Limit Display - Speed Limit Display
- Stability Improvements - Stability Improvements
- Faster Startup!! - Startup Faster!
- Display OPS and RVC at the same time - Display and RVC OPS at the same time
- Display Off on extras tab - Display Off on extras tab
- Climatronic control if approriate climatronic fitted - Climatronic control if fitted approriate Climatronic
- Clock display if RNS 510 swtiched off - Clock display if RNS 510 swtiched off
- Excluded roads (under route options) - Excluded roads (under itinerary options)
- on display together OPS and rear cam ( like audi) etc. - On display together OPS and rear cam (like audio) etc.
