Mira el siguiente enlace:Cita:
Espero te sirva de ayuda, y nos muestres lo que pedimos. Salu2
Monday,28,September,2015,14:19:37:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ1PZ9R046373 License Plate:
Mileage: 126480km-78591mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ9R046373 Mileage: 126480km/78591miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 SF HW: 03G 906 021 AN
Component: R4 2,0L EDC G000SG 1454
Revision: --H08--- Serial number: SEX7Z0I031M09N
Coding: 0050072
Shop #: WSC 06402 785 00200
VCID: 75E1075F1C34EDB6B75-8020
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B401209260000880E02EB901C00423400
Shop #: WSC 04941 000 00000
VCID: 74E73A5BD74EF4BE80B-8021
1 Fault Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 222
Mileage: 126483 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 2
Count: 12288
Count: 320
Count: 43776
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D51EF3FB4E4E5760F5-8078
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000005977116
Coding: 81880F2F00041000431D00000000000000017F075C40000000 0000000000
VCID: 3365F94752C0B386591-8066
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 191108 022 0601
Coding: 00056208
Shop #: WSC 06402
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A01 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP0L4RV4
Coding: 0012337
VCID: 3B75D1677A907BC6811-806E
Subsystem 1 - Serial number: 6333FTS606270069
Subsystem 2 - Serial number: 6343FTS600452958
Subsystem 3 - Serial number: 6353ETS6KAH5V5KJ
Subsystem 4 - Serial number: 6363ETS6KOVHV5KR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0002042
VCID: 78FF0E6B0B2690DEAC3-802D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Part No: 1P0 920 847 F
Component: KOMBIINSTRUMENT VO3 1052
Coding: 0002101
Shop #: WSC 06795 116 50998
VCID: 3561C75F5CB4ADB6775-8060
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08B2603CB
Coding: E9807F06000602000202
VCID: 377DCD5746B85FA6659-8062
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 1052
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000292588812
Coding: 0004272
VCID: 408FA68B1376181ED43-8015
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 998000005283CC7F0006850560084F86307C00
Shop #: WSC 30589 224 63747
VCID: 8305E987C2E04306091-80D6
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 30589
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000340488826
Coding: 0004272
VCID: 4189A38F187C1116DBD-8014
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186 B
Component: Radio BVX 0007
Coding: 0042424
VCID: 2B55E1278AF0EB46111-807E
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388 TUER-SG HL 1401
Revision: 11006001 Serial number: 00000003580996
Coding: 0000144
VCID: 74E73A5B174EF4BE80B-8021
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389 TUER-SG HR 1401
Revision: 11006001 Serial number: 00000003608396
Coding: 0000144
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2P5x H30 0110
Revision: 00000001 Serial number: 00000005058665
Coding: 0000555
VCID: 326BFC43ADDABA8E527-8067
le acabo de pasar el vagcom al coche xk no se porque hoy se le han quedado parpadeando la luz del abs y la del asr o como se diga.... eso nunca me lo habia hecho antes...
y no son los mismos fallos que me daba antes... es como si no me reconocieran partes del coche... no se... hare lo que me habeis dicho.. desmontare las ruedas y mirare los sensores a ver que tal...
Tienes activado el system fuction test, por eso se te queda encendido las luces de abs y asr.
Para desactivar ese modo tienes que entrar en Adaptation en el modulo de ABS y leer el canal 103
Enviado desde mi GT-S7560 mediante Tapatalk
De memoria no me acuerdo, pero una vez arranques el vag-com entra en el modulo del ABS, busca un grupo que te de el valor de velocidad de cada rueda y pinchas en la casilla de grafica.
Lo que te dije fue hacer un LOG de los captores del ABS, eso sería vital. Que mires los captores de ABS y pruebes a limpiarlos eso está cojonudo, pero el LOG dejaría todo claro. Salu2Cita:
1 Fault Found:
Lo primero que haria seria quitar ese fallo.
De la siguiente manera.
Entra con el vag com en el modulo de ABS luego meter el login 40168, te vas a basic setting y pones el canal 103 y se tiene que quitar, si no se quita en ese mismo canal cambias el 1 por el 0.
