Bueno, aquí va la lectura del vagcom, he intentado con la versión 17.8 y me da error, me dice que estado de interfaz ilocalizable, lo he hecho con la versión 12.12 y este es el resultado:
VCDS Version: Release 12.12.0
Data version: 20130910
Saturday,17,February,2018,21:25:14:62939
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan:
[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
VIN: VSSZZZ6LZ6R564186 Mileage: 163950km/101873miles
Address 01: Engine Labels: Redir Fail!
Part No:
[Only registered and activated users can see links. Click Here To Register...] BR
Component: 1,4l R3 EDC G000SG 7626
Coding: 00102
Shop #: WSC 06402
VCID: 66C350130292162E0EF-4A3A
VSSZZZ6LZ6R564186 SEZ5Z0F3261185
3 Faults Found:
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 35-00 - No Signal
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 35-10 - Open or Short to Ground - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: 0 2 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H04 0002
Revision:
[Only registered and activated users can see links. Click Here To Register...] Serial number:
Coding: 0002160
Shop #: WSC
VCID: 8109E38FDBFC51161BD-5000
1 Fault Found:
01314 - Engine Control Module
Freeze Frame:
Fault Status:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 230
Mileage: 163757 km
Time Indication: 0
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 E
Component: CLIMAtronic PQ24 3805
Shop #: WSC
VCID: 285F1E2B9806C05EFC3-5000
5 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
01273 - Fresh Air Blower (V2)
00457 - Control Module for Network (J519)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 00012
Shop #: WSC 06402
VCID: 3C77D27B2C9E7CFE88B-5000
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 AD
Component: 02 AIRBAG VW5 0010
Coding: 12338
Shop #: WSC 06401
VCID: 79F90B6F632C89D6D3D-5000
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 6L0-920-xx3-17.lbl
Part No: 6L0 920 802 A
Component: KOMBI+WEGFAHRS. AGD V07
Coding: 00145
Shop #: WSC 00050
VCID: 285F1E2BC806C05EFC3-5000
3 Faults Found:
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
49-10 - No Communications - Intermittent
01176 - Key
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 006D GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
VCID: F0EFB64BB056489EE43-5072
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AF
Component: LenkhilfeKYO V957
Coding: 10111
Shop #: WSC 06402
VCID: 73E539474140F386991-5000
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortgerát 0002
Coding: 00018
Shop #: WSC 06402
VCID: 3D71DF7F378475F6BF5-4A3A
A ver que podéis sacar en claro de aquí.
Muchas gracias.
