a 31 de enero que es hoy, todavía no he podido instalar los radares y oírlos. A diferencia de muchos que les pasa lo contrario, que los oyen pero no los ven. Como se activa las notificaciones para los radares? Gracias Xisu
De verdad que te has leído este hilo ?
Muchas gracias por la aportacion.
# This is the description file for the Software Update of Volkswagen components
[common]
Vendor = "Volkswagen"
Variant = "FM?-H-*-*-*"
Variant2 = "17206"
Variant3 = "17207"
Variant4 = "37206"
Variant5 = "37207"
Variant6 = "47203"
Variant7 = "47204"
Variant8 = "17216"
Variant9 = "17217"
Variant10 = "37212"
Variant11 = "37213"
Variant12 = "47208"
Variant13 = "47209"
Variant14 = "17212"
Variant15 = "37208"
Variant16 = "47205"
Variant17 = "17222"
Variant18 = "47210"
Variant19 = "17224"
Variant20 = "37214"
Variant21 = "17210"
Variant22 = "17220"
Variant23 = "17245"
Variant24 = "17246"
Variant25 = "17250"
Variant26 = "17251"
Variant27 = "17247"
Variant28 = "17252"
Variant29 = "17254"
Variant30 = "17255"
Variant31 = "17268"
Variant32 = "17269"
Variant33 = "17270"
Variant34 = "17271"
Region = "Europe"
Region2 = "RoW"
Region3 = "USA"
MetafileChecksum = "c90567f504051fdf72c736914dab87fe2ef5c939"
[common_Release_1]
Name = "MIB 2 High Personal POI"
Path = "./PersonalPOI/MIB2HIGH"
Region = "Europe"
Region2 = "RoW"
Region3 = "USA"
[common_Release_2]
Name = "MIB 2 Standard Delphi Personal POI"
Path = "./PersonalPOI/MIB2DE"
Variant = "17245"
Variant2 = "17246"
Variant3 = "17250"
Variant4 = "17251"
Variant5 = "17247"
Variant6 = "17252"
Variant7 = "17254"
Variant8 = "17255"
Variant9 = "17268"
Variant10 = "17269"
Variant11 = "17270"
Variant12 = "17271"
Region = "Europe"
Region2 = "RoW"
Region3 = "USA"
[common_Release_3]
Name = "MIB 2 Standard TechniSat Personal POI"
Path = "./PersonalPOI/MIB2TSD"
Variant = "17206"
Variant2 = "17207"
Variant3 = "37206"
Variant4 = "37207"
Variant5 = "47203"
Variant6 = "47204"
Variant7 = "17216"
Variant8 = "17217"
Variant9 = "37212"
Variant10 = "37213"
Variant11 = "47208"
Variant12 = "47209"
Variant13 = "17212"
Variant14 = "37208"
Variant15 = "47205"
Variant16 = "17222"
Variant17 = "47210"
Variant18 = "17224"
Variant19 = "37214"
Variant20 = "17224"
Variant21 = "37214"
Region = "Europe"
Region2 = "RoW"
Region3 = "USA"
[Signature]
signature1 = "9880af1b5d5456de15affd708b3b74b2"
signature2 = "3cf0dbe1d0baf902e43229a07cfb9281"
signature3 =
Iniciado por barracus71 [Only registered and activated users can see links. Click Here To Register...]
Hola quisiera participar aclarando poco a poco un monton de información que me he bajado de muchos foros como este y clarificar el porque no funcionan los radares y como esta todo en relación al discover media, discover pro tarjetas de datos y muchísimas otras cosas mas. Quiero dejaros este link, de momento, con la estructura de como van los radares en la tarjeta SD. Mas adelante la explicación de que es cada archivo, y quien genera estos archivos etc.
Entero. Pero no hay manera. Bueno miento, a decir verdad si he podido instalarlos y verlos, en una de esas ocasiones en que le da por cargar. Pero no se exactamente donde está el error. Cada vez que se genera un error, me dice que se ha generado un error y que va a reiniciar el sistema para que no hayan errores. Y en el reinicio resetea todos los pois que hayas introducido. Se pone a "por defecto" y otra vez a meter radares. Y esto es un bucle. Es un poco raro todo.
Buen@s!
Ayer me puse a mirar de que forma podría modificar los gráficos del paquete "PersonalPOI", con el que nos obsequia XISU y que tan bien nos va, ya que los que trae no me acaban de parecer "integrados" con los del Discover. Me puse a mirar, y encontré unos que me parecieron bastante acertados, y sin pensármelo me puse a ello.
Conseguí (-a falta de soft editor de pois adecuado-, a la "fuerza", meterlos en el paquete "PersonalPOI_2017_01_18_v2". Los nuevos gráficos lucen así en el Discover:
Algo que hay que mencionar, es que al momento de instalarlos, no aparecen inmediatamente en la pantalla del navegador, al parecer por algún tema de cache. Si aparecen en los menús de selección pero tardan en aparecer en el navegador.
Para quien quiera cambiar de gráficos, es relativamente fácil hacerlo mediante "fuerza bruta", sin apenas software especial:
1º.- Conseguir los iconos que más te gusten (o los que más se acerquen ;-)
2º.-Ponerlos a un tamaño en pixels de 39x39 (igual en otro tamaño funciona, pero no lo he probado. Este tamaño me parece adecuado)
3º- Hacerte con una utilidad para calcular el CheckSum de los ficheros. Si utilizas Windows, puedes descargarde la utilidad "fciv.exe", que te permitirá obtener el chksum SHA-1 que es el que entiende el Discover.
4º.-Debes anotar para cada fichero el tamaño en bytes (ojo, no en Kbytes), además de su checksum SHA-1.
5º.- Con estos datos ya puedes en primer lugar "machacar" los ficheros que hay en el paquete "PersonalPOI", con los tuyos, (los encontraras en las carpetas: "PersonalPOI\MIB2HIGH\PersonalPOI\Package\0\defaul t\bitmaps", y en la carpeta: "PersonalPOI\MIB2TSD\personalpoi\ppoidb\1\default\ icon", del paquete descomprimido.
6º.- Aquí viene la parte más delicada: Debes editar los ficheros "hashes.txt", que están en las carpetas: " PersonalPOI\MIB2TSD\personalpoi\ppoidb\1\default", y en "PersonalPOI\MIB2HIGH\PersonalPOI\Package\0\defaul t", en elloos encontraras para cada Bitmap/Icono una entrada como la siguiente:
FileName = "bitmaps/001_image.png"
FileSize = "1185"
CheckSumSize = "524288"
CheckSum = "c65711b335de41377befbc1d11c8b7ed200b50a9"
Las que hay que modificar para cada bitmap/icono son: "FileSize", indicando el tamaño en bytes del fichero al que se hace referencia en el apartado "FileName", y el apartado "CheckSum", con el checksum que resulte de cada fichero. (El chksum es una comprobación de suma de bytes que conforman el fichero, y se utiliza para verificar la corrección del mismo. Y Discover la utiliza..)
Para los impacientes, os adjunto mi versión, trabajada a partir de la ultima versión que hay disponible al inicio del foro, con los gráficos que le he metido. (Estaría bien conocer el soft de edición de POIs que se esta utilizando, ya que ayudaría a mejorar el tema bastante...XISU, please puedes darnos luz?)
En primer lugar gracias a todos por toda la información de este hilo.
Instale hace unos días los avisos radares y aunque se veían en el navegador como POIs,
cuando los marcaba [Ajustes --> Mapa], al volver al navegador, se desmarcaban.
Una y otra vez al marcar en la pantalla los POIs y volver al navegador no aparecian
como marcados, pero no solo no se mantenían los POIs de los radares sino que pasaba lo
mismo si marcaba cualquiera de los originales del navegador. No se mantenía ninguno.
Aunque el sonido de aviso de los radares sonaba siempre.
A veces, al encender el navegador, aparecían marcados, pero al arrancar desaparecían.
Otras veces, en marcha, se matenían marcados, pero si paraba el motor, al volver
arrancar desaparecían. Desinstalé e Instalé varias veces. Todo igual.
Pasé por el taller VW (dentro de la garantía).
Han actualizado el software del navegador y solucionado, ahora funciona.
Se ven las imágenes, de cualquier POI marcado.
Gracias, pero ¿a que te refieres con marca de avisar al conductor antes de llegar a los radares??
¿Como suenan los radares?
A mi me suena un "check" es decir, un sonido pequeño, corto, y bastante suave.
Lo cual me genera un problema porque si llevo musica o cualquier cosa, normalmente, no me entero. ¿Se puede cambiar el sonido?
