SW:070-906-016-BA HW:028-101-166-4 --- Engine
;Component:R5 2 5L EDC G000SG 7001 Coding:0000132
;Thursday 3 January 2019 16:09:13:06091
;VCDS Version: Release 18.9.0 (x64) Data version: 20180927 DS296.0
;VCID: D0EC264142F478CA86-5184
Group Field 1 Data type Field 2 Data type Field 3 Data type Field 4
1 819 /min 4.9 mg/str 7.1°KW 86.4°C
2 798 /min 0.00% 0 01 0 86.4°C
3 777 /min 245.0 mg/str 240.0 mg/str 43.00%
4 777 /min 5.0 °BTDC 7.7°KW -4.9°KW
5 798 /min 20.6 mg/str 48 86.4°C
6 0.0 km/h 1000 0.00% 10
7 66.6°C 22.5°C 87.3°C
8 819 /min 0.0 Nm 187.9 Nm 126.9 Nm
9 798 /min -1280.0 Nm 500.2 Nm 126.9 Nm
10 240.0 mg/str 1030.2 mbar 1030.2 mbar 0.00%
11 777 /min 1020.0 mbar 1030.2 mbar 80.50%
12 11111111 0.00 s 14.52 V 87.3°C
13 0.16 mg/str 0.47 mg/str 0.05 mg/str 0.00 mg/str
14 -0.71 mg/str
15 819 /min 36.6 Nm 0.60 l/h 0.0 Nm
16 35.70% 14.59 V
17 0 0 0 0
18 0 0 0 0
19 0
20 777 /min 51.2 Nm 1270.0 Nm -1280.0 Nm
21 0 0 100
22 1 1 0 16
23 -28 -23 -45 -23
24 -57
25 1848 /min 4 0
26 E27E
27 1 0.0 km/h 190.0 km/h
28 0.304 V 0 01 0 0.00%
29 88.2°C 44.0 mm
51 819 /min 399 /min 48 1010000
55 0 0 100000 100000
56 100000 100000 100000 0xFF00
62 86.4°C 35.1°C 4.5°C 23.4°C
64 86.4°C 35.1°C 10.10%
80 BPG-810 31.01.05 12345678 1883 0106
81 WV1ZZZ7HZ5H078895 VWZ7Z0E1560290 1234567
82 0020078502756 <> 78 020L 79 <>
125 ABS 1 Instruments 1 Airbag 1
126 Cent. Elect. 1
131 16 5.2 mg/str 86.4°C
133 798 /min 235.0 mg/str 1030.2 mbar 0
134 35.70% 14.52 V
140 -0.56 mg/str
145 0
150 -51
213 798 /min 0.00% 0.0 km/h 0
225 0 0 0 0
226 0 0 0
227 0 0 0 0
228 0 0
229 0 0
252 Cent. Elect
Otro Mapa de valores de Motor 2.5TDI
SW:070-997-016-D HW:028-101-073-3 --- Engine
;Component:R5 2,5L EDC G000SG 7596, Coding:0001072
;Friday,18,January,2019,16:04:32:20365
;VCID: 1B3123CAD9EA4D9220-515A
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,798 /min,RPM,7.1 mg/str,Inj. Quantity,7.1°KW,Idle Stabilization,79.2°C,Temperature,
2,798 /min,RPM,0.0 %,Load, 0 01 0,Bin. Bits,79.2°C,Temperature,
3,798 /min,RPM,235.0 mg/str,Mass Air / Rev.,235.0 mg/str,Mass Air / Rev.,41.0 %,Duty Cycle,
4,798 /min,RPM,7.1 °BTDC,Ign. Timing,7.1°KW,Idle Stabilization,-3.4°KW,Idle Stabilization,
5,798 /min,RPM,12.4 mg/str,Inj. Quantity,48.0,(no units),79.2°C,Temperature,
6,0.0 km/h,Speed,00001100,Bin. Bits,0.0 %,Load,00000010,Bin. Bits,
7,59.4°C,Temperature,0.0 %,Load,19.8°C,Temperature,79.2°C,Temperature,
8,798 /min,RPM,-2.4 Nm,Torque,234.2 Nm,Torque,156.2 Nm,Torque,
9,798 /min,RPM,-1280.0 Nm,Torque,500.2 Nm,Torque,156.2 Nm,Torque,
10,240.0 mg/str,Mass Air / Rev.,999.6 mbar,Absolute Pres.,989.4 mbar,Absolute Pres.,0.0 %,Load,
11,798 /min,RPM,1009.8 mbar,Absolute Pres.,989.4 mbar,Absolute Pres.,78.9 %,Duty Cycle,
12,11111111,Bin. Bits,0.00 s,Time,14.14 V,Voltage,79.2°C,Temperature,
13,0.07 mg/str,Inj. Quantity,-0.71 mg/str,Inj. Quantity,0.54 mg/str,Inj. Quantity,-0.09 mg/str,Inj. Quantity,
14,0.16 mg/str,Inj. Quantity, , , , , , ,
15,798 /min,RPM,70.8 Nm,Torque,1.00 l/h,Fuel Consump.,-2.4 Nm,Torque,
16,38.0 %,Load, , , , ,14.06 V,Voltage,
17,00000000,Bin. Bits,01000100,Bin. Bits,10000000,Bin. Bits,10000000,Bin. Bits,
18,0.0,(no units),0.0,(no units),0.0,(no units),0.0,(no units),
19,0.0,(no units), , , , , , ,
20,798 /min,RPM,68.3 Nm,Torque,1270.0 Nm,Torque,-1280.0 Nm,Torque,
21,00000000,Bin. Bits, , ,00000000,Bin. Bits,00000100,Bin. Bits,
22,1.0,(no units),1.0,(no units),0.0,(no units),16.0,(no units),
23,-65.0,(no units),-58.0,(no units),-49.0,(no units),-66.0,(no units),
24,-58.0,(no units), , , , , , ,
25,798 /min,RPM, , ,4.0,(no units),0.0,(no units),
26,C5C6,RPM,
27,1.0,(no units), , ,0.0 km/h,Speed,190.0 km/h,Speed,
29,79.2°C,Temperature, , , , , , ,
51,798 /min,RPM,399 /min,RPM,48.0,(no units),01010000,Bin. Bits,
55,0.0,(no units),0.0,(no units),00100000,Bin. Bits,00000000,Bin. Bits,
56,00100000,Bin. Bits,00100000,Bin. Bits,00000000,Bin. Bits,0xFF00,Hex Value,
60,798 /min,RPM,65.9 Nm,Torque,79.2°C,
