Como has puesto la info del Climatizador, ahí aparece el fichero lbl correspondiente y, entonces, se puede ver qué Grupos de valores tiene:
Dirección 08: Aire acondicionado Labels: 3C0-907-044.LBL
Nº pieza SW: 3C0 907 044 BT HW: 3C0 907 044 BT
Componente: ClimatronicPQ46 122 0707
; VCDS Label File
; Copyright © 2005-2010 Ross-Tech, LLC
; VW Passat (3C)
; Component: J255 - A/C Heating Electronics (#08) - Climatronic
; P/N: 3C0-907-044-???
; includes measuring blocks, basic setting and adaptation
; created on 17/Dec/2005 by Sebastian Stange (sebastian@ross-tech.com)
; last modification on 18/Jun/2010
; requires VCDS 805.0 or newer
; measuring blocks & basic setting
001,0,General
001,1,Compressor,Shut-Off Code
001,2,Engine Speed
001,3,Vehicle Speed
001,4,Standing Time
B001,0,Potentiometer && Flap Alignment
B001,1, , ,
B001,2, , ,
B001,3, , ,
B001,4, , ,
002,0,Compressor
002,1,Compressor,Current (actual)
002,2,Compressor,Current (specified)
002,3,Compressor,Rotations
002,4,Compressor Load
003,1,Coolant,Pressure
003,2,Radiator Fan,Activation (actual)
003,3,Radiator Fan,Activation (spec.)
003,4,Engine Speed,(increase)
004,0,Temperatures
004,1,Outside Temp.,Unfiltered
004,2,Outside Temp.,Regulation
004,3,Fresh Air Intake,Temperature
004,4,Coolant,Temperature
005,0,Outlet/Footwell Blower Temperature
005,1,Left Outlet Blower,Temperature,Display Range: 0...84 °C
005,2,Right Outlet Blower,Temperature,Display Range: 0...84 °C
005,3,Left Footwell,Blower Temp.,Display Range: 0...84 °C
005,4,Right Footwell,Blower Temp.,Display Range: 0...84 °C
006,1,Evaporator,Temperature
006,2,Interior,Temperature
006,3,Sunlight,Intensity (G107),W/m²
007,0,Fresh Air Blower (V2)
007,1,Fresh Air Blower,Voltage (act.),Display Range: 0.0...13.0 V
007,2,Fresh Air Blower,Voltage (spec.),Display Range: 0.0...13.0 V
007,3,Fresh Air Blower,Load,Display Range: 0.0...100.0 %
007,4,Voltage,(Terminal 30)
008,3,Dimming,(Terminal 58d),Display Range: 0.0...100.0 %
008,4,Country,,1 = Rest of World (RoW)\n2 = North America (NAR)
009,1,Rear Window,Heater (Z2 / Actual)
009,2,Rear Window,Heater (Z2 / Spec.)
009,3,Aux. Heater,Status,Display Range: ON/OFF
009,4,Aux. Heater,Current
010,1,Aux. Heater,Request,Display Range: ON/OFF
010,2,Heater OFF,,Display Range: ON/OFF
010,3,Back-Up Lights,,Display Range: ON/OFF
010,4,Front Wiper,,Display Range: ON/OFF
011,0,Air Recirculation Flap Control Motor (V113) / Potentiometer (G143)
011,1,Current Value
011,2,Specified Value
011,3,Minimum Position,(Lower Stop/Close)
011,4,Maximum Position,(Upper Stop/Open)
012,0,Left Temperature Flap Control Motor (V158) / Potentiometer (G220)
012,1,Current Value
012,2,Specified Value
012,3,Minimum Position,(Lower Stop/Close)
012,4,Maximum Position,(Upper Stop/Open)
013,0,Right Temperature Flap Control Motor (V159) / Potentiometer (G221)
013,1,Current Value
013,2,Specified Value
013,3,Minimum Position,(Lower Stop/Close)
013,4,Maximum Position,(Upper Stop/Open)
014,0,Center Flap Control Motor (V70) / Potentiometer (G112)
014,1,Current Value
014,2,Specified Value
014,3,Minimum Position,(Lower Stop/Close)
014,4,Maximum Position,(Upper Stop/Open)
015,0,Defroster Flap Control Motor (V107) / Potentiometer (G135)
015,1,Current Value
015,2,Specified Value
015,3,Minimum Position,(Lower Stop/Close)
015,4,Maximum Position,(Upper Stop/Open)
016,0,Air Flow Flap Control Motor (V71) / Potentiometer (G113)
016,1,Current Value
016,2,Specified Value
016,3,Minimum Position,(Lower Stop/Close)
016,4,Maximum Position,(Upper Stop/Open)
080,0,Advanced Control Module Identification I
; adaptation
A001,0,Air Flow Flap Control Motor (V71)
A001,5,Air Flow Flap Control Motor (V71)
A001,6,0 = Vehicles with separate Air Flow Flap Control Motor (through ca. MY 2007)
A001,7,1 = Vehicles w/o separate Air Flow Flap Control Motor (from ca. MY 2008)
A001,8,
A001,9,Only effects the following Control Modules:
A001,10,3C0-907-044-* (from SW 0707)
A001,11,
A001,12,Note: See TPI 2016077 (VW).
