El valor deberia ser: 0001612
Volante multifunción con levas y función mute para el botón de micrófono teniendo limpia trasero
muchas gracias PASPAS, Pero para MF sin levas y función mute para el botón de micrófono teniendo limpia trasero, esto ultimo seria un 2 verdad?Cita:
o sea seria 0000512?
es que juraría que probé este código y no me funcionaba pero ya no estoy seguro.
edito para poner que he probado 100 codigos y nada de nada, sigo con el 0000112, que me funciona hasta la estrella como mute, sera por la maneta antigua del los limpias tendre que cambiarla?
UNa pregunta por que hay centralitas ah con esta codificaccion;
Steering Wheel Electronics (J527) Coding
?xxxxxx: Voice Operation (Symbols)
0 = No Voice Operation (Standard Symbols)
1 = Voice Operation (Modified Symbols)
0?xxxxx: Country (Parking Light)
0 = Rest of World (with Parking Light)
1 = North America (without Parking Light)
0x?xxxx: Vehicle Type
0 = Normal Vehicle
1 = Special Purpose Vehicle (e.g. Taxi)
0xx?xxx: Transmission
0 = Manual Transmission
1 = Automatic Transmission (Rest of World)
2 = Automatic Transmission (North America)
0xxx?xx: Steering Wheel/Tiptronic
0 = without Multi-Function Steering Wheel
1 = with Multi-Function Steering Wheel / without Tiptronic
2 = with Multi-Function Steering Wheel / with Tiptronic
3 = with Multi-Function Steering Wheel / without Tiptronic / with Push-To-Talk (PTT)
4 = with Multi-Function Steering Wheel / with Tiptronic / with Push-To-Talk (PTT)
0xxxx?x: Cruise Control
0 = without Cruise Control System
1 = with Cruise Control System
2 = with Cruise Control System and Distance Regulation
0xxxxx?: Rear Wiper/Board Computer
1 = without Rear Wiper (Sedan) / without Board Computer
2 = with Rear Wiper (Wagon) / without Board Computer
3 = without Rear Wiper (Sedan) / with Board Computer
4 = with Rear Wiper (Wagon) / with Board Computer
y con esta otra?
Lensäulenelektronik (J527) Codierung
0?xxxxx: Drive-Assist-Systems
0 = with Drive-Assist-System-Message w/o Button
1 = w/o Drive-Assist-System-Message w/o Button
2 = with Drive-Assist-System-Message with Button
3 = w/o Drive-Assist-System-Message with Button
0x?xxxx: Multi-Function Control Module (J608)
0 = J608 not installed
1 = J608 installed (J527 as Master)
2 = J608 installed (J608 as Master)
0xxx?xx: Steering Wheel/Tiptronic/Push-To-Talk (PTT)
0 = Multi-Function Steering Wheel not installed
5 = Multi-Function Steering Wheel w/o Tiptronic and w/o Push-To-Talk (PTT) installed
6 = Multi-Function Steering Wheel with Tiptronic and w/o Push-To-Talk (PTT) installed
7 = Multi-Function Steering Wheel w/o Tiptronic and with Push-To-Talk (PTT) installed
8 = Multi-Function Steering Wheel with Tiptronic and with Push-To-Talk (PTT) installed
0xxxx?x: Cruise Control System (CCS) and Adaptive Cruise Control (ACC)
0 = Cruise Control System (CCS) not installed
1 = 6 Position Cruise Control System (CCS) installed
0xxxxx?: Rear Wiper and Wiper Stalk for Board Computer
1 = Rear Wiper not installed / Wiper Stalk for Board Computer not installed
2 = Rear Wiper installed / Wiper Stalk for Board Computer not installed
3 = Rear Wiper not installed / Wiper Stalk for Board Computer installed
4 = Rear Wiper installed / Wiper Stalk for Board Computer installedy
La distinta codificación depende de la versión de software de la centralita.
La ayuda inferior es para centralitas que, digamos, usan el volante de Golf VI. Mientras que la superior es para volantes de tipo Golf V.
Ahora bien, que no coja la codificación es porque ya tienes la correcta.
Asumo que tienes un volante de tipo Golf V (más que nada por la codificación que te deja marcar, que para volante de Golf VI no existe codificaciones con valores de '1' en las centenas).
Por lo tanto,
- en las centenas tienes el valor '1': 1 = with Multi-Function Steering Wheel / without Tiptronic
- en las decenas tienes el valor '1': 1 = with Cruise Control System
- en las unidades tienes el valor '2': 2 = with Rear Wiper (Wagon) / without Board Computer
Aunque en el caso de la codificación de las unidades, deberías tener el valor '4' with Rear Wiper (Wagon) / with Board Computer
Prueba con esta a ver si te funciona el control del ordenador de a bordo con los botones de la botonera derecha del volante: 0000114
Exacto, tenia un volante de 4 radios SIN multifuncion y puse un de tres radios MF, si ya pobre con esa, y me deja de funcionar el volante y me funciona la maneta, La verdad es que compre esta centralita para poner el otro volante, pero por temas económicos puse este y vendo el otro, y rezaba para que la centralita valiese.Cita:
Ayer estuve 1 hora hora metiendo códigos y nada, y por lo que veo tengo dos opciones, o lo dejo así o pongo otra centralita con otro software no?, Es que le vi el coding de conforline del passat sin fallos con el volante golf5 gti con esta centralita y pensé que valia.
Muchas gracias PAS-PAS
