Component: J220 - Engine (#01) - AUM/BAE
; measuring blocks & basic setting
001,0,General
001,1,Engine Speed,(G28)
001,2,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
001,3,Lambda Control,Bank 1
001,4,Basic Setting,Requirements,See Label File
; 1xxxxxxx - Coolant temperature above 80 °C
; x1xxxxxx - Engine speed below 2000 RPM
; xx1xxxxx - Throttle valve closed
; xxx1xxxx - Lambda regulation correct
; xxxx1xxx - State of idle
; xxxxx1xx - A/C system compressor deactivated
; xxxxxx1x - Catalytic converter over 300 °C
; xxxxxxx1 - No malfunction detected by Self-Diagnosis
002,0,General
002,1,Engine Speed,(G28)
002,2,Engine Load
002,3,Injection Timing
002,4,Mass Air Flow,(G70)
003,0,General
003,1,Engine Speed,(G28)
003,2,Mass Air Flow,(G70)
003,3,Throttle Valve Angle
003,4,Ignition,Timing Angle
004,0,General
004,1,Engine Speed,(G28)
004,2,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
004,3,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
004,4,Intake Air,Temperature (G42),Range: -40.5...+135.0 °C\nSpecification (Warm): < +80.0 °C (max. +115.0 °C)
005,0,General
005,1,Engine Speed,(G28)
005,2,Engine Load
005,3,Vehicle Speed,,Range: 0.0...255.0 km/h
005,4,Load Status,,Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
006,0,General
006,1,Engine Speed,(G28)
006,2,Engine Load
006,3,Intake Air,Temperature (G42),Range: -40.5...+135.0 °C\nSpecification (Warm): < +80.0 °C (max. +115.0 °C)
006,4,Altitude,Correction Factor
008,1,Brake,Status
010,0,Ignition
010,1,Engine Speed,(G28)
010,2,Engine Load
010,3,Throttle Valve Angle
010,4,Ignition,Timing Angle
011,0,Ignition
011,1,Engine Speed,(G28)
011,2,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
011,3,Intake Air,Temperature (G42),Range: -40.5...+135.0 °C\nSpecification (Warm): < +80.0 °C (max. +115.0 °C)
011,4,Ignition,Timing Angle
014,0,Ignition (Misfire Recognition - Total)
014,1,Engine Speed,(G28)
014,2,Engine Load
014,3,Misfire,(total),Specification: 0
014,4,Misfire,Recognition,Range: Disabled/Enabled
015,0,Ignition (Misfire Recognition - Cylinder 1-3)
015,1,Misfire Counter,Cylinder 1
015,2,Misfire Counter,Cylinder 2
015,3,Misfire Counter,Cylinder 3
015,4,Misfire,Recognition,Range: Disabled/Enabled
016,0,Ignition (Misfire Recognition - Cylinder 4)
016,1,Misfire Counter,Cylinder 4
016,4,Misfire,Recognition,Range: Disabled/Enabled
018,0,RPM/Load Barriers
018,1,Lower,RPM Barrier
018,2,Upper,RPM Barrier
018,2,Lower,Load Barrier
018,3,Upper,Load Barrier
020,0,Ignition (Timing Retardation Cylinder 1-4)
020,1,Timing Retardation,Cylinder 1
020,2,Timing Retardation,Cylinder 2
020,3,Timing Retardation,Cylinder 3
020,4,Timing Retardation,Cylinder 4
022,0,Ignition (Timing Retardation Cylinder 1 && 2)
022,1,Engine Speed,(G28)
022,2,Engine Load
022,3,Timing Retardation,Cylinder 1
022,4,Timing Retardation,Cylinder 2
023,0,Ignition (Timing Retardation Cylinder 3 && 4)
023,1,Engine Speed,(G28)
023,2,Engine Load
023,3,Timing Retardation,Cylinder 3
023,4,Timing Retardation,Cylinder 4
026,0,Ignition (Knock Control Cylinder 1-4)
026,1,Voltage,Cylinder 1
026,2,Voltage,Cylinder 2
026,3,Voltage,Cylinder 3
026,4,Voltage,Cylinder 4
028,0,Ignition (Knock Sensor Test)
028,1,Engine Speed,(G28)
028,2,Engine Load
028,3,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
028,4,Result,,Range: Test ON/Test OFF/Sys. OK/Sys. not OK\nSpecification: Sys. OK
B028,0,Ignition (Knock Sensor Test - Short Trip)
; "Activate" Basic Setting
; Firmly press Brake Pedal and Throttle Pedal at once
; Engine Speed increases to 2200 RPM automatically > Field 4 = Test ON
; Wait until Field 4 shows "Sys. OK"
B028,1,Engine Speed,(G28)
B028,2,Engine Load
B028,3,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
B028,4,Result,,Range: Test ON/Test OFF/Sys. OK/Sys. not OK\nSpecification: Sys. OK
030,0,Lambda Control (Sensor Status)
030,1,Bank 1,Sensor 1
; 1xx - Lambda Sensor Heating on
; x1x - Lambda Sensor ready
; xx1 - Lambda Control active
030,2,Bank 1,Sensor 2
; xx1 - Lambda Control (I-Portion) active
031,0,Lambda Control
031,1,Lambda Control,Bank 1 (actual)
031,2,Lambda Control,Bank 1 (specified)
032,0,Lambda Control (Mixture Adaptation)
032,1,Adaptation (Idle),Bank 1 Sensor 1
032,2,Adaptation (Partial),Bank 1 Sensor 1
033,0,Lambda Control
033,1,Lambda Control,Bank 1 Sensor 1
033,2,Sensor Voltage,Bank 1 Sensor 1
034,0,Lambda Control (Aging Check: Bank 1 Sensor 1)
034,1,Engine Speed,(G28)
034,2,Catalytic Converter,Bank 1 Temp.
034,3,Dynamic Factor,Bank 1 Sensor 1
034,4,Result,Lambda Aging,Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK\nSpecification: Test OFF
B034,0,Lambda Control (Aging Check: Bank 1 Sensor 1)
; Engine Speed increases automatically > Field 4 = Test ON
; Wait until Field 4 shows "B1-S1 OK"
B034,1,Engine Speed,(G28)
B034,2,Catalytic Converter,Bank 1 Temp.
B034,3,Dynamic Factor,Bank 1 Sensor 1
B034,4,Result,Lambda Aging,Range: Test ON/Test OFF/B1-S1 not OK/B1-S1 OK\nSpecification: B1-S1 OK
036,0,Lambda Control (Sensor Readiness - After Catalyst)
036,1,Sensor Voltage,Bank 1 Sensor 2
036,2,Result,Lambda Availability,Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK\nSpecification: Test OFF
B036,0,Lambda Control (Sensor Readiness - After Catalyst)
; Wait until Field 4 shows "B1-S2 OK"
B036,1,Sensor Voltage,Bank 1 Sensor 2
B036,2,Result,Lambda Availability,Range: Test ON/Test OFF/B1-S2 not OK/B1-S2 OK\nSpecification: B1-S2 OK
037,0,Lambda Control (Delta Lambda Bank 1)
037,1,Engine Load
037,2,Sensor Voltage,Bank 1 Sensor 2
041,0,Lambda Control (Lambda Sensor Heating Bank 1)
041,1,Resistance,Bank 1 Sensor 1
041,2,Heater Condition,,Display Range: Htg. S1 OFF/Htg. S1 ON
041,3,Resistance,Bank 1 Sensor 2
041,4,Heater Condition,,Display Range: Htg. S2 OFF/Htg. S2 ON
043,0,Lambda Control (Aging Check: Bank 1 Sensor 2)
043,1,Engine Speed,(G28)
043,2,Catalytic Converter,Bank 1 Temp.
043,3,Lambda Voltage,Bank 1 Sensor 2
043,4,Result,Aging Check,Display Range: Test ON/Test OFF/B1-S2 OK/B1-S2 n.OK\nSpecification: Test OFF
B043,0,Lambda Control (Aging Check: Bank 1 Sensor 2)
B043,1,Engine Speed,(G28)
B043,2,Catalytic Converter,Bank 1 Temp.
B043,3,Lambda Voltage,Bank 1 Sensor 2
B043,4,Result,Aging Check,Display Range: Test ON/Test OFF/B1-S2 OK/B1-S2 n.OK\nSpecification: B1-S2 OK
046,0,Lambda Control (Catalytic Conversion Test Bank 1)
046,1,Engine Speed,(G28)
046,2,Catalytic Converter,Bank 1 Temp.
050,0,Engine Speed Increase
050,1,Engine Speed,(actual)
050,2,Engine Speed,(specified)
050,3,A/C Readiness,,Display Range: A/C-Low / A/C-High
050,4,A/C Compressor,,Display Range: Compr.OFF/Compr.ON
051,0,Engine Speed Increase (Gear shifts)
051,1,Engine Speed,(actual)
051,2,Engine Speed,(specified)
051,3,Selected Gear,,P or N = 0\nGear = 1 - 6\nR = 7
051,4,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
053,0,Engine Speed Increase (Generator Load)
053,1,Engine Speed,(actual)
053,2,Engine Speed,(specified)
053,3,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
053,4,Generator,Load Signal
054,0,Idle Speed Stabilization
054,1,Engine Speed,(G28)
054,2,Load Status,,Display Range: Idle/Partial Throttle/Wide Open Throttle (WOT)/Enrichment/Deceleration
054,3,Accel. Pedal Pos.,Sensor 1 (G79)
054,4,Throttle Valve Angle
055,0,Idle Speed Stabilization
055,1,Engine Speed,(G28)
055,2,Idle Regulator
055,3,Idle Stabilization,Self-Adaptation
055,4,Operating,Condition
; 0xxx? = A/C Compressor
; 0xx?x = Gear engaged
; 0x?xx = A/C Readiness
; 0?xxx = Rear Window Heater
056,0,Idle Speed Stabilization
056,1,Engine Speed,(actual)
056,2,Engine Speed,(specified)
056,3,Idle Regulator
056,4,Operating,Condition
060,0,Electronic Throttle (Throttle Body Adaptation)
060,1,Throttle Valve,Sensor 1 (G187)
060,2,Throttle Valve,Sensor 2 (G188)
060,3,Throttle Adaptation,Steps Counter
060,4,Result,Throttle Valve Adp.,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
B060,0,Electronic Throttle (Throttle Body Adaptation)
; Wait until Field 4 shows "ADP OK"
B060,1,Throttle Valve,Sensor 1 (G187)
B060,2,Throttle Valve,Sensor 2 (G188)
B060,3,Throttle Adaptation,Steps Counter
B060,4,Result,Throttle Valve Adp.,Range: ADP RUN/ADP OK/ADP ERROR\nSpecification: ADP OK
061,0,Electronic Throttle
061,1,Engine Speed,(G28)
061,2,Battery Voltage,(Terminal 30),Specification: 11.0...15.0 V
061,3,Throttle Valve Angle
061,4,Operating,Condition
062,0,Electronic Throttle (Sensor Values)
062,1,Throttle Valve,Sensor 1 (G187)
062,2,Throttle Valve,Sensor 2 (G188)
062,3,Accel. Pedal Pos.,Sensor 1 (G79)
062,4,Accel. Pedal Pos.,Sensor 2 (G185)
063,0,Electronic Throttle (Kick-Down Adaptation)
063,1,Accel. Pedal Pos.,Sensor 1 (G79)
064,0,Electronic Throttle (Sensor Adaption Values)
064,1,Lower Adaptation,Sensor 1 (G187)
064,2,Lower Adaptation,Sensor 2 (G188)
064,3,Emergency Air Gap,Sensor 1 (G187)
064,4,Emergency Air Gap,Sensor 2 (G188)
066,0,Electronic Throttle (Cruise Control System)
066,1,Vehicle Speed,(current)
066,2,Switch Positions I,,See Label File
; xxxxxxx? = Brake Light Switch
; xxxxxx?x = Brake Pedal Switch
; xxxxx?xx = Clutch Pedal Switch
; xxxx?xxx = CCS (Cruise Control System) enabled
; xxx?xxxx = ACC (Adaptive Cruise Control) available
; xx?xxxxx = Main Switch engaged
; ??xxxxxx = CCS Status
066,3,Vehicle Speed,(specified)
066,4,Switch Positions II,,See Label File
; x0xxxxx? = CCS ON (CAN)
; x0xxxx?x = SET (CCS ON)
; x0xxx?xx = Deceleration (-)
; x0xx?xxx = Acceleration (+)
; x0x?xxxx = SET
; x0?xxxxx = RESUME/RESET
; ?0xxxxxx = CCS ON (Hardware Pin)
070,0,Emission Reduction (EVAP Valve Test)
070,1,Evap. Emissions,Sol. Valve (Open)
070,2,Lambda Control
070,4,Result,,Range: Test ON/Test OFF/TEV OK/TEV not OK\nSpecification: Test OFF
B070,0,Emission Reduction (EVAP Valve Test)
; Wait until Field 4 shows "TEV OK"
B070,1,Evap. Emissions,Sol. Valve (Open)
B070,2,Lambda Control
B070,4,Result,,Range: Test ON/Test OFF/TEV OK/TEV not OK\nSpecification: TEV OK
077,0,Emission Reduction (Secondary Air Injection: Bank 1)
077,1,Engine Speed,(G28)
077,2,Mass Air Flow,(G70)
077,3,Air Mass from,Sec. Air Inj. Bank 1
077,4,Result,,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Test OFF
B077,0,Emission Reduction (Secondary Air Injection: Bank 1)
; Engine Speed increases to 1400 RPM automatically > Field 4 = Test ON
; Wait until Field 4 shows "Syst. OK"
; NOTE: Can only be performed once per engine start!
B077,1,Engine Speed,(G28)
B077,2,Mass Air Flow,(G70)
B077,3,Air Mass from,Sec. Air Inj. Bank 1
B077,4,Result,,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Syst. OK
080,0,Advanced Control Module Identification I
081,0,Advanced Control Module Identification II
081,1,Vehicle Ident.,Number (VIN)
081,2,Immobilizer,Ident. (IMMO-ID)
082,0,Advanced Control Module Identification III
086,0,Readiness Code I
086,1,Readiness Bits,,See Label File\n\n0 = completed\n1 = not completed
; xxxxxxx? = Catalyst(s)
; xxxxxx?x = Catalyst Heating
; xxxxx?xx = EVAP System
; xxxx?xxx = Secondary Air Injection System
; xxx?xxxx = Climate Control
; xx?xxxxx = Oxygen Sensor(s)
; x?xxxxxx = Oxygen Sensor Heating
; ?xxxxxxx = Exhaust Gas Recirculation (EGR)
086,2,Cycle Flags I,,See Label File\n\n0 = completed\n1 = not completed
; xxxxxxx? = Catalyst Bank 1
; xxxxxx?x = Catalyst Bank 2
; xxxxx?xx = Leak Diagnostic Pump
; xxxx?xxx = EVAP Valve
; xxx?xxxx = Oxygen Sensor Heater Bank 1 Sensor 1
; xx?xxxxx = Oxygen Sensor Heater Bank 1 Sensor 2
; x?xxxxxx = Oxygen Sensor Heater Bank 2 Sensor 1
; ?xxxxxxx = Oxygen Sensor Heater Bank 2 Sensor 2
086,3,Cycle Flags II,,See Label File\n\n0 = completed\n1 = not completed
; 0xxxxxx? = Bank 1 Sensor 1 elec.
; 0xxxxx?x = Bank 1 Sensor 2 elec.
; 0xxxx?xx = Bank 1 Sensor 1 (Delta-Lambda Shift)
; 0xxx?xxx = Bank 1 Sensor 2 (Sensor Aging)
; 0xx?xxxx = Bank 1 Sensor 1 (Period Duration)
; 0x?xxxxx = Secondary Air Injection Bank 1
; 0?0xxxxx = Secondary Air Injection Bank 2
086,4,Cycle Flags II,,See Label File\n\n0 = completed\n1 = not completed
; 0xxxxxx? = Bank 2 Sensor 1 elec.
; 0xxxxx?x = Bank 2 Sensor 2 elec.
; 0xxxx?xx = Bank 2 Sensor 1 (Delta-Lambda Shift)
; 0xxx?xxx = Bank 2 Sensor 2 (Sensor Aging)
; 0xx?xxxx = Bank 2 Sensor 1 (Period Duration)
; 0?xxxxxx = Secondary Air Injection Bank 2
087,0,Readiness and Error Bits
087,1,Readiness Bits,,See Label File\n\n0 = completed\n1 = not completed
087,2,Error Flags I,,See Label File\n\n0 = completed\n1 = not completed
087,3,Error Flags II,,See Label File\n\n0 = completed\n1 = not completed
087,4,Error Flags II,,See Label File\n\n0 = completed\n1 = not completed
88,0,Cycle Flags
88,1,Cycle Flags I,,See Label File\n\n0 = completed\n1 = not completed
; xxxxxxx? = Exhaust Camshaft Bank 2
; xxxxxx?x = Exhaust Camshaft Bank 1
; xxxxx?xx = Intake Camshaft Bank 2
; xxxx?xxx = Intake Camshaft Bank 1
; xxx?xxxx = Knock Sensor 4
; xx?xxxxx = Knock Sensor 3
; x?xxxxxx = Knock Sensor 2
; ?xxxxxxx = Knock Sensor 1
88,2,Cycle Flags II,,See Label File\n\n0 = completed\n1 = not completed
; xxxxxx?x = Clutch Pedal Switch
; xxxxx?xx = Idle Speed Control
; xxxx?xxx = Speed Signal
; xxx?xxxx = Idle Switch
; xx?xxxxx = Coolant Temperature Sensor
; x?xxxxxx = Throttle Valve Potentiometer
; ?xxxxxxx = Mass Air Flow Sensor
88,3,Cycle Flags III,,See Label File\n\n0 = completed\n1 = not completed
; xxx0x?00 = Intake Air Temperature Sensor
; xxx0?x00 = Thermostat (only USA)
; xx?0xx00 = Cruise Control Lever
; x?x0xx00 = Oxygen Sensor Control - Adaptation Bank 2
; ?xx0xx00 = Oxygen Sensor Control - Adaptation Bank 1
090,0,Camshaft Adjustment (Intake)
090,1,Engine Speed,(G28)
090,2,Camshaft Adjustm.,Status
090,3,Camshaft Adjustm.,Bank 1
091,0,Camshaft Adjustment (Intake Bank 1)
091,1,Engine Speed,(G28)
091,2,Engine Load
091,3,Camshaft Adjustm.,Status
091,4,Camshaft,Adjustment
093,1,Engine Speed,(G28)
093,2,Engine Load
094,0,Camshaft Adjustment (Intake)
094,1,Engine Speed,(G28)
094,2,Camshaft Adjustm.,Status
094,3,Result,Bank 1
099,0,Lambda Control Shut-Off
099,1,Engine Speed,(G28)
099,2,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
099,3,Lambda Control
099,4,Lambda Control,Status,Range: O2-Reg.OFF/O2-Reg.ON
B099,0,Lambda Control Shut-Off
; Wait until Field 4 shows "O2-Reg.OFF"
B099,1,Engine Speed,(G28)
B099,2,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
B099,3,Lambda Control
B099,4,Lambda Control,Status,Range: O2-Reg.OFF/O2-Reg.ON
100,0,Readiness Code
100,1,Readiness Bits,,See Label File
; xxxxxxx? - Catalytic Converter
; xxxxxx?x - Catalytic Converter Heater
; xxxxx?xx - Activated Charcoal System
; xxxx?xxx - Secondary Air Injection (AIR) System
; xxx?xxxx - A/C System
; xx?xxxxx - Oxygen Sensors
; x?xxxxxx - Oxygen Sensor Heating
; ?xxxxxxx - Exhaust Gas Recirculation (EGR)
100,2,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
100,3,Time since,Engine Start
100,4,OBD-Status,,See Label File
; xxxx00x? - Warm-Up Cycle not possible
; xxxx00?x - Warm-Up Cycle ended
; xxx?00xx - Malfunction detected (min. 1 Fault)
; xx?x00xx - Trip complete
; x?xx00xx - Driving Cycle detected
; ?xxx00xx - MIL ON
101,0,Fuel Injection
101,1,Engine Speed,(G28)
101,2,Engine Load
101,3,Injection Timing
101,4,Mass Air Flow,(G70)
102,0,Fuel Injection
102,1,Engine Speed,(G28)
102,2,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
102,3,Intake Air,Temperature (G42),Range: -40.5...+135.0 °C\nSpecification (Warm): < +80.0 °C (max. +115.0 °C)
102,4,Injection Timing
104,0,Fuel Injection (Start Adaption Values)
104,1,Engine Start,Temperature
107,0,Fuel Injection (Fuel Supply System)
107,1,Engine Speed,(G28)
107,2,Lambda Control,Bank 1
107,4,Result,Lambda Control,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Test OFF
B107,0,Fuel Injection (Fuel Supply System)
B107,1,Engine Speed,(G28)
B107,2,Lambda Control,Bank 1
B107,4,Result,Lambda Control,Display Range: Test ON/Test OFF/Syst. OK/Syst. n.OK\nSpecification: Syst. OK
110,0,Load Registration (Load/Full Throttle Enrichment)
110,1,Engine Speed,(G28)
110,2,Coolant,Temperature (G62),Range: -40.5...+135.0 °C\nSpecification (Warm): 80.0...115.0 °C
110,3,Injection Timing
110,4,Throttle Valve Angle
111,0,Boost Pressure Control
111,1,RPM Range 1
111,2,RPM Range 2
111,3,RPM Range 3
111,4,RPM Range 4
113,0,Load Registration (Load/Full Throttle Enrichment)
113,1,Engine Speed,(G28)
113,2,Engine Load
113,3,Throttle Valve Angle
113,4,Athmospheric,Pressure
114,0,Boost Pressure Control
114,1,Engine Load,(specified)
114,2,Engine Load,(spec. corrected)
114,3,Engine Load,(actual)
114,4,Wastegate (N75),Duty Cycle
115,0,Boost Pressure Control
115,1,Engine Speed,(G28)
115,2,Engine Load
115,3,Boost Pressure,(specified)
115,4,Boost Pressure,(actual)
116,0,Boost Pressure Control
116,1,Engine Speed,(G28)
116,2,Fuel Temp.,Correction Factor
116,3,Coolant Temp.,Correction Factor
116,4,Intake Air Temp.,Correction Factor
117,0,Boost Pressure Control
117,1,Engine Speed,(G28)
117,2,Accel. Pedal Pos.,Sensor 1 (G79)
117,3,Throttle Valve Angle
117,4,Boost Pressure,(specified)
118,0,Boost Pressure Control
118,1,Engine Speed,(G28)
118,2,Intake Air,Temperature (G42)
118,3,Wastegate (N75),Duty Cycle
118,4,Boost Pressure,(actual)
119,0,Boost Pressure Control
119,1,Engine Speed,(G28)
119,2,Charge Limit
119,3,Wastegate (N75),Duty Cycle
119,4,Boost Pressure,(actual)
120,0,Traction Control (ASR)
120,1,Engine Speed,(G28)
120,2,Torque specified,by ASR
120,3,Engine Torque,(actual)
120,4,Traction Control,Status,Specification: ASR OFF/ASR ON
122,0,Transmission
122,1,Engine Speed,(G28)
122,2,Engine Load,(specified)
122,3,Engine Load,(actual)
122,4,Status,,Range: Engine interv./No engine interv.
125,0,CAN-Databus Communication (Powertrain)
125,1,Transmission,Electronics,Range: Transm. 1/Transm. 0
125,2,Brake Electronics,(J104),Specification: ABS 1\nRange: ABS 1/ABS 0
125,3,Instrument Cluster,(J285),Specification: Instruments 1\nRange: Instruments 1/Instruments 0
125,4,Heating/Air,Condition (J255),Specification: A/C 1\nRange: A/C 1/A/C 0
; adaptation
A091,0,Immobilizer Status
A091,5,Immobilizer Status (Read Only)
A091,6,0 = Immobilizer not matched (NEW)
A091,7,1 = Immobilizer disabled
A091,8,4 = Immobilizer matched (System OK)
; coding
;C00,Engine (J220) Coding
; coding-2
;L00,Engine (J220) Coding-2
; readiness
O,06A-906-032-AUM
En estos motores no hay posibilidad de medir la presión del combustible con el VAG-COM (la válvula reguladora de presión no lleva sensor)
