Entiendo, que estás 2 averías del principio, salen cuando se enciende el testigo de avería, que luego borras averías y sigues usando el coche tras salir del taller:
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 LG HW: 03L 906 023 KL
Component and/or Version: 1,6l R4 CR td H43 8832
Software Coding: 00114016032401080000
Work Shop Code: WSC 06402 785 00200
ASAM Dataset: EV_ECM16TDI02013L906023LG 003005 (VW36 *)
ROD: N/A
VCID: 76E43D9AC95C7DF1C3-8022
No ASAM data for: "EV_ECM16TDI02013L906023LG" (VW36 *)
2 Faults Found:
7286 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 90995 km
Date: 2017.11.14
Time: 11:41:58
9854 - ROD - Unknown Error Code
- 00 [175]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91080 km
Date: 2000.00.00
Time: 00:00:00
y estás, supongo que tras borrar averías ese día, han salido de nuevo:
Readiness: 0100 0000
070 VA0 570901076
Despues:
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LG HW: 03L 906 023 KL
Component: 1,6l R4 CR td H43 8832
Revision: --H43--- Serial number:
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM16TDI20103L906023LG 003005
ROD: N/A
No ASAM data for: "EV_ECM16TDI20103L906023LG" (VW36 *)
2 Faults Found:
- 00 [032]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 90995 km
Date: 2017.11.14
Time: 11:41:58
- 00 [237]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91080 km
Date: 2000.00.00
Time: 00:00:00
Si estoy en lo cierto, se ha vuelto a registrar de nuevo tras pasar por el taller, está avería:
- 7286 - Turbocharger Boost Control Position Sensor Circuit - Implausible Signal.
Y se registra esta nueva, que no salía antes y te pongo lo que es y cómo solucionarla:
VAG Error Code: 13812/9854
EOBD II Error Code: P246F
Fault Location:
Exhaust Gas Temperature (EGT) [Only registered and activated users can see links. Click Here To Register...] (G648), Bank 1 - Circuit Range/Performance Problem/Implausible Signal
Possible Cause:
Wiring/Connector(s).
Exhaust Gas Temperature (EGT) Sensor 4 (G648), Bank 1.
Engine Control Module (ECM).
Possible Solutions:
Check/Replace all faulty Wiring/Connector(s).
Read Measuring Value Blocks (MVB).
Check/Replace [Only registered and activated users can see links. Click Here To Register...] Gas Temperature (EGT) [Only registered and activated users can see links. Click Here To Register...] (G648), Bank 1.
Tú al recoger el coche no borraste averías?? se quedaron todas borradas en el módulo de motor? porque intento saber si se han registrado de nuevo o no para saber si son reales de verdad o no. Pusiste la misma batería que llevabas? mismo amperaje, marca y potencia de arranque??
