ayuda instalacion bixenon
buenas,estoy haciendo la instalacion bixenon en una touran 1t2, y no me deja configurar me pone estos fallos.
VCDS Version: Release 15.7.0 Running on Windows XP x86
Data version: 20150820
Monday,30,April,2018,15:56:14:04550
Chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 15 16 17 18 19 25 37 42 44 46 52 55 56 62 72
76
VIN: WVGZZZ1TZ7W081202 Mileage: 446680km-277554miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 MP HW: 03G 906 021 AN
Component: R4 2,0L EDC G000AG 0486
Revision: --H06--- Serial number: VWX7Z0G23NN0G0
Coding: 0000078
Shop #: WSC 01324 785 00200
VCID: 791C0E6BF0D602DA828060-802C
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 042 F HW: 02E 927 770 AE
Component: GSG DSG 070 0920
Revision: 04507000 Serial number: 00000510010163
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 16C625D7E188CDA20FE2A3-8042
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023238
VCID: 73003C43D2BA788AC8BCA2-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006888273
Coding: 038B8F2100040F0047120C0000000000000A7F075C0001
VCID: 6C32273F8F84A7720906F1-8038
Subsystem 1 - Part No: 2K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 150307 020 0501
Coding: 00038805
Shop #: WSC 01324
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 446681 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 04 AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D03A9Y6
Coding: 0012340
VCID: 3686C55781482DA22F2203-8062
Subsystem 1 - Serial number: 6332QSME24421F7DN
Subsystem 2 - Serial number: 6342QSME277443137
Subsystem 3 - Serial number: 6352QSME22393D71H
Subsystem 4 - Serial number: 6362QSME22384A7DR
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 636 0070
Coding: 0010042
VCID: 00EA638F930C5312C53E55-8054
Part No SW: 1T0 920 873 E HW: 1T0 920 873 E
Component: KOMBIINSTRUMENT VDD 3808
Revision: V0001000 Serial number: VWX7Z0G23NN0G0
Coding: 0007101
Shop #: WSC 00001 001 00001
VCID: 3798C8538642D4AA341436-8062
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 T
Component: Zuheizer 050 2504
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
2 Faults Found:
02251 - Heater Unit Locked
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 314675 km
Time Indication: 0
01415 - Recirculating Pump (V55)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 254
Reset counter: 32
Mileage: 267200 km
Time Indication: 0
Freeze Frame:
Locked
Temperature: 15.0°C
Temperature: 18.0°C
Voltage: 11.78 V
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 200307F1001852
Coding: 7F3F174807008002
VCID: 2F88F0337E121C6A6CE45E-807A
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 3808
Address 37: Navigation Labels: 1K0-035-191.lbl
Part No SW: 1K0 035 191 D HW: 1K0 035 191 D
Component: J401 0206
Revision: 00018000 Serial number: VWZ1Z2G7130973
Coding: 0041400
VCID: 23A00C0322DAA80AF85CD2-8076
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 200
Mileage: 446681 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:19
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 E HW: 1T0 959 701 E
Component: Tuer-SG 005 0937
Coding: 0000181
VCID: 399CCE6BB056C2DAC20020-806C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.071 H07 1806
VCID: 3482FF5F97343FB2113669-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 809002085103087F2D06840560084F03E0FC00
VCID: 03E06C83821A480AD81C72-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 E HW: 1T0 959 702 E
Coding: 0000180
VCID: 3A9ED167B550C9C2CB7AD7-806E
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 A HW: 5M0 907 357 A
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 3293188
VCID: 328EF9476D20318203CA7F-8066
Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
Component: AFS-Lst.-Modul l ....
Coding: 00000255
Subsystem 2 - Part No: ID-R fehlt Labels: ID-55-02.CLB
Component: AFS-Lst.-Modul r ....
Coding: 00000255
6 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 446681 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:28
Freeze Frame:
Voltage: 10.93 V
Speed: 0.0 km/h
ABS 1
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 446681 km
Time Indication: 0
Date: 2000.00.00
Time: 04:41:28
Freeze Frame:
Voltage: 10.93 V
Speed: 0.0 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 56: Radio Labels: 1K0-035-191.lbl
Component: R 0206
Coding: 0041400
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 200
Mileage: 446681 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:19
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0906
Coding: 0000144
Shop #: WSC 01324 785 1012552
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
VCID: 389ACB6F8B5CDBD23D0E3D-806C
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 05 Einparkhilfe 0101
VCID: 2DB4EA3B741E6E7A5EF8A4-8078
End-------------------------(Elapsed Time: 02:15)--------------------------
