Problema no arranca mi Golf VI 2.0 TDI de 2009
Hola soy nuevo y ya vengo con problemas jaja me recomendaron este foro porque entendéis más de la marca, bueno vamos al grano.
Tengo un Golf 2.0 tdi de 110cv de 2009 con tan solo 170mil km
cuando le paso el vag com me dice esto:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 MC HW: 03L 906 022 G
Component: R4 2.0l TDI 0000SG 9977
Revision: 13H01--- Serial number:
Coding: 0000071
Shop #: WSC 49986 002 1048576
VCID: 72EC018A6D3461D1EF-8026
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: None
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B200D092700FF881404E4901F00423000
VCID: 76E43D9AC15C7DF1C3-8022
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
Component: Climatronic 130 0303
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 73E2048EDA2E68D9E4-8026
1 Fault Found:
9481200 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 105
Mileage: 171365 km
Date: 2019.08.08
Time: 03:58:23
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 HW: 1K0 937 086
Component: BCM PQ35 M 020 BCM PQ35 M 020 03580358
Revision: 00020000
Coding: 40180A3A90251AC040000080100081E445010088524D896064 8000000000
Shop #: WSC 01357 011 00200
VCID: 6DD612F6B40ABE2932-8038
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 24110 21 0501
Coding: 009795
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 022 0507
Serial number: 003C2D06E3FP
Coding: 00003135
ASAM Dataset: EV_AibraVW10SMEVW360 A01003
ROD: N/A
VCID: 77FA309ECE5604F9D8-8022
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V U01 ----
Serial number: 39751244ZZZZZZZZZZZZ
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V U01 ----
Serial number: 104C4345ZZZZZZZZZZZZ
Component: S.Sens.Fahr.H --- ----
Serial number: 0213127CZZZZZZZZZZZZ
Component: S.Sens.Beif.H --- ----
Serial number: 283C145FZZZZZZZZZZZZ
No ASAM data for: "EV_AibraVW10SMEVW360" (VW36)
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 853 0111
Coding: 0000004
VCID: 0302544E428E5859F4-8056
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 860 E HW: 5K0 920 860 E
Component: KOMBI H21 0029
Serial number: 00000000000000
Coding: 170B00
ASAM Dataset: EV_Kombi_UDS_DVD_RM09 A04020
ROD: N/A
VCID: 2E54D5FA718C05314B-807A
No ASAM data for: "EV_Kombi_UDS_DVD_RM09" (VW36 *)
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 161108F2000779
Coding: E9807F06000212000002
VCID: 377AF09E46D6C4F918-8062
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H21 0029
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667317464
Coding: 010000
VCID: 26442DDA517C4D71B3-8072
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AM HW: 1K0 959 701 AM
Component: Tuer-SG 008 2015
Coding: 0000180
VCID: 79FE36A630421289AE-802C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
Shop #: WSC 01324 785 00200
VCID: 2A5CD9EA8564691197-807E
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 171365 km
Time Indication: 0
Date: 2013.12.29
Time: 03:59:41
Freeze Frame:
Battery Volts: 12.0 V
DD
Temperature: 35.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AM HW: 1K0 959 702 AM
Coding: 0000180
VCID: 7AFC29AA35441991A7-802E
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 012 0029
Revision: 00000000 Serial number: VWZ1Z2H5885510
Coding: 0100040004
VCID: 65C66AD66CFA86697A-8030
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
VCID: 7BF22CAE3A7E2099BC-802E
End-------------------------(Elapsed Time: 02:32)--------------------------
Como nota se le cambio el sensor del árbol de levas eso si por uno de desguace pero ya seria coincidencia que tampoco funcionará.. y el sensor del cigüeñal este si por uno nuevo (todavía no tuve tiempo a enchufarle la maquina a ver si sigue dando fallo, se le hizo la distribución con útiles como tiene que hacerse el calado todo correcto, lo intente arrancar pero... no arranco todo sigue igual) que podrá ser?
