Pues bien este es problema que os decia cuando aparece el testigo parpadenado todo el rato
Me juego un sugus a que es EGR agarrada...
Bueno pues ya me llego el cable y he realizado el autoscan y estos son los errores que tengo
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 906 018 CD HW: 03G 906 018 CD
Component: R4 2.0l PPD1.5 G 9970
Revision: --H05--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 09038 572 92676
VCID: 69DE66E640E2A2095E-803C
1 Fault Found:
16955 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 11101000
Fault Priority: 4
Fault Frequency: 6
Reset counter: 114
Mileage: 151630 km
Time Indication: 0
Date: 2017.06.18
Time: 19:46:50
Freeze Frame:
RPM: 800 /min
Text: 32 Nm
Speed: 0.0 km/h
Text: 0.0 %
Voltage: 13.22 V
Bin. Bits: 00101110
Text: 184 Nm
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658441400
Coding: 0015650
Shop #: WSC 00175 572 13917
VCID: 3068CB82A3B813C159-8064
1 Fault Found:
00599 - Plausibility of Pressure/Brake Light Switch
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 124
Reset counter: 128
Mileage: 151339 km
Time Indication: 0
Date: 2017.06.01
Time: 08:46:41
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AA HW: 3C0 907 044 AA
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 60C87BC2B3D8E34189-8034
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000005226567
Coding: 01800F0700041000000A00000F00000000095D435C0000
Shop #: WSC 00137 211 56823
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00137
1 Fault Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 251
Reset counter: 139
Mileage: 145884 km
Time Indication: 0
Date: 2016.09.19
Time: 13:01:00
Freeze Frame:
ON
Voltage: 13.55 V
ON
ON
OFF
OFF
ON
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 04 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2PP80P3F
Coding: 0012340
Shop #: WSC 05311 000 00000
VCID: 2D56D2F6B48A7E2972-8078
Subsystem 1 - Serial number: 6332MSME0D56105A
Subsystem 2 - Serial number: 6342MSME0D2C1C49
Subsystem 3 - Serial number: 6351HTS6I2I64A83
Subsystem 4 - Serial number: 6361HTS67SDQTNJ2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 B HW: 3C0 953 549 B
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C5953507E
Coding: 0000111
VCID: 2B52DCEE8A9E70196C-807E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul 007 0050
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 870 Q HW: 3C0 920 870 Q
Component: KOMBIINSTRUMENT VD1 4240
Revision: X0033000 Serial number: 00000000000000
Coding: 0007105
VCID: 316ECE86A8B21AC956-8064
1 Fault Found:
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 156
Mileage: 151625 km
Time Indication: 0
Date: 2017.06.18
Time: 11:29:47
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05B29087A
Coding: 3DFD2C04C21002
VCID: 214E3EC6F852AA49C6-8074
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 09038 572 83354
VCID: 326CC18AADB421D12F-8066
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0000181
VCID: 3664FD9A41DC3DF103-8062
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 79408 027 739526
VCID: 3460C79257A02FE13D-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0455
Coding: 18910A0801860E763804941570084F0B603C00
Shop #: WSC 09038 572 81508
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 377AF09E46D6C4F918-8062
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
Component: EPB VD8HC005 013 0005
Revision: 013
Coding: 0000012
VCID: 26442DDA917C4D71B3-8072
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E3009451
Coding: 0040400
VCID: 3362C48E52AE28D924-8066
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2432
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
A ver si me podeis ayudar a saber que fallos tiene el coche
Sensor de pedal de freno
Por lo que ha pasado en otros vag y por los errores que marca, el muelle amarillo es por el sensor del pedal de freno, aunque no relaciono esa avería con que el acelerador no vaya bien. Lo suyo es que cambies el sensor y luego ver si sigue pasando lo del acelerador, que imagino que no.
Para probarlo pisa el freno y que alguien te diga si encienden las luces.
Si el coche piensa que se está pisando el freno ésta señal por seguridad manda mas que la señal del acelerador y el coche deja de acelerar
Es como dice zx10. Si estás acelerando y tocas el freno, deja de acelerar.
Cambia el sensor y seguro que se soluciona el problema.
Hola
Te dejo unos bricos de dos formas de cambiar el sensor ( sigue la fase 2 pues quitas menos pieças em el coche para lhegar al mismo resultado, tu eliges).
Perdona estar escrito em português pero creo que lo puedes entender.
Saludos desde PORTUGAL
