no encuentro el modulo 55.
pongo el autoscan completo por si te sirve
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-DFSB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 016 GN HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1668
Revision: 8AH20---
Coding: 01190032042415090000
Shop #: WSC
ASAM Dataset: EV_ECM20TDI01104L906016GN 001003
ROD: EV_ECM20TDI01104L906016GJ_VN35.rod
VCID: 7BF59D8AF2244A9AF5-802E
2 Faults Found:
17158 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [032] - -
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision:
[Only registered and activated users can see links. Click Here To Register...] Serial number:
Coding: 1079409BB367B47E0878027DCD8B2DD378F1F0
Shop #: WSC
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_VN35.rod
VCID: 3F8D299AA6BC96BA99-806A
1 Fault Found:
0397 - TPMS Warning
C102D F0 [008] - Pressure Loss
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 3
Mileage: 23571 km
Date: 2013.14.14
Time: 18:54:21
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 1K8 907 044 CD HW: 1K8 907 044 CD
Component: Climatronic H08 0405
Revision: 00001K05
Coding:
Shop #: WSC
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 73E5B5AADA7402DAAD-8026
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+
Revision: BD122001
Coding: 671A0ABA8065086F08880080950089EC03DD0008426D8120E4 84C7000041
Shop #: WSC
VCID: 73E5B5AAD27402DAAD-8026
Subsystem 1 - Part No: 2K1 955 119 D
Component: Wischer 10091 26 0512
Coding: 009795
Subsystem 2 - Part No: 5K7 955 559 C
Component: RLS
[Only registered and activated users can see links. Click Here To Register...] 42 0106
Coding: 0228DD
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 76
Mileage: 25443 km
Time Indication: 0
Date: 2014.14.11
Time: 17:13:26
Freeze Frame:
Term 15 Off
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 1K8 919 475 D HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0480
Revision: -------- Serial number:
Coding:
Shop #: WSC
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00.rod
VCID: 3B755D8AB2A48A9AB5-806E
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0210
Serial number:
Coding: 00000000FE0339
Shop #: WSC
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 36634CBE898657F24A-8062
Address 15: Airbags (J234) Labels: None
Part No SW: 2K5 959 655 C HW: 2K5 959 655 C
Component: VW10Airbag00G H08 0018
Revision: -------- Serial number: 003V20012G6I
Coding: 000000000000000000000000000000003047
Shop #: WSC
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3C775E96B7AA8DA2BC-8068
Crash sensor for side airbag: driver side:
Serial number: 3497ARB404P42KLSC03M
Crash sensor for side airbag: front passenger side:
Serial number: 3507ARB404P42KLSHGUJ
Crash sensor for side airbag: rear: driver side:
Serial number: 3517ARB405342KLSFPCV
Crash sensor for side airbag: rear: passenger side:
Serial number: 3527ARB405N44QG0911T
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 GE HW: 5K0 953 569 BF
Component: LENKS.MODUL
Revision: FF010042 Serial number:
Coding:
Shop #: WSC
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 75E18BB2D4001CEA83-8020
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 2K0 959 442 HW: 2K0 959 442
Component: E221__MFL-TAT H06 0023
Serial number: 2141600580900106BA1B
Coding: 280000
Address 17: Instruments (J285) Labels: None
Part No SW: 2K5 920 876 F HW: 2K5 920 876 F
Component: KOMBI H03 1104
Serial number:
Coding: 110A011200
Shop #: WSC
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 387F42868392A18258-806C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 180916F1000009
Coding: 357430
Shop #: WSC
VCID: 7BF59D8AFA244A9AF5-802E
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 25991 km
Time Indication: 0
Date: 2014.14.21
Time: 10:49:41
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
Shop #: WSC
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADBA8CE8DBEC3121E-803E
Address 42: Door Elect, Driver Labels: None
Part No SW: 2K5 959 701 A HW: 2K5 959 701 A
Component: Tuer-SG
Coding: 0136242
Shop #: WSC
VCID: 326B70AEADEE4BD266-8066
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
Shop #: WSC
VCID: 397947827098B88AA7-806C
Address 4C: Tire Pressure II
Cannot be reached
Address 52: Door Elect, Pass. Labels: None
Part No SW: 2K5 959 702 A HW: 2K5 959 702 A
Component: Tuer-SG
Coding: 0136242
Shop #: WSC
VCID: 336575AA52F442DA6D-8066
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5C0 035 680 D HW: 5C0 035 680 D
Component: MU-S-N-ER H31 0359
Serial number: VWZAZ2S5278067
Coding: 06330701BE00000011110001000808001F0100D400200100CF
Shop #: WSC
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_SK25.rod
VCID: 224B80EE350EDB5296-8076
Data medium:
Subsystem 1 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Serial number: --------------------
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: 030F1873
Shop #: WSC
VCID: 71E9BFA2A86830CA5F-8024
Subsystem 1 - Part No SW: 2K0 915 181 HW: 2K0 915 181
Component: J367-BDMConti H03 1050
Serial number: 75410603001609112755
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Towbar module H09 0100
Revision: 3A001001 Serial number: ÀÁ006789000000
Coding:
Shop #: WSC
VCID: 306F7AA663E279C210-8064
End-------------------------(Elapsed Time: 02:59)--------------------------
