Puerta piloto y aguja temperatura loca
Muy buenas compañeros:
Pues después de adquirir un passat 3bg con 132000 kilómetros le he un autoscan con vag com 12.12 y esto es lo que me ha salido
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 KD
Component: 1,9l R4 EDC 0000SG 4897
Coding: 00002
Shop #: WSC 05314
VCID: 63C54907F1A06306E91-49D8
WVWZZZ3BZ4E346279 VWZ7Z0D9446838
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04255
Shop #: WSC 05311
VCID: 2541171FBF14DD36C75-5072
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 K
Component: CLIMATRONIC B5GP 0010
Coding: 17000
Shop #: WSC 05311
VCID: 29591B2FD30CF956E3D-5000
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 0E AIRBAG VW61 04 0003
Coding: 12357
Shop #: WSC 05311
VCID: 24470A1BB42E243ED0B-5000
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 829 A
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 05115
Shop #: WSC 00000
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 03 Komfortgerát HLO 0004
Coding: 00259
Shop #: WSC 05311
VCID: 3663C05312B2A6AE7EF-4A3A
Subsystem 1 - Part No: 1C1959801
Component: 03 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 03 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 03 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 03 Tõrsteuer.HR KLO 0202
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
la aguja de la temperatura motor esta loca, de repente baja, de repente sube a 90.... no se si esta mal el tablero o algo del motor
luego la puerta del conductor hay veces que se cierra y otras no....
Por otro lado, no tengo ni idea de mecánica y veo mucho cosas por aquí que no entiendo muy bien...
el coche era del padre de una amiga de mi moza y esta tal y como salio del concesionario, sin ninguna mod ni nada, algo que poco a poco iré haciendo y sobre todo preguntando mucho....
me gustaría si podéis que me recomendaras cosas básicas que le puedo hacer yo al coche sin liarla....
lo primero y principal hacer un backup de como esta el coche... me parece lo mas basico
el otro día cuando hice el auto scan active el auto lock, algo que ha veces no funciona y creo que es por la cerradura...
recomendaciones para hacerle al coche, egr con el manual de M0nch0? modificar el angle synchro??? n75??
seria recomendable comprar algún producto de esos que se echan en el deposito para limpiar el motor o inyectores o esas cosas???
algo para bajar el consumo??? repro??
gracias, saludos y perdón por el tostón
