Cita:Cita:
Exacto, tengo el Original Rosstech , recomiendas o no actualizar a la Beta 16.1.4 ?
Cita:Cita:
Si quiere utilizar VAGCOM x debajo de la versión 15.7.4 NO ACTUALICESCita:
Al actualizar sale la advertencia que os comento!
Más información donde me enteré la información BETA 16.3.0/1
Has puesto la ruleta de los espejos en el lado derecho antes de meter la marcha?Cita:
Iniciado por FernandoPH [Only registered and activated users can see links. Click Here To Register...]
Aquí el aviso, en su versión Shakespeariana y su correspondencia CervantinaCita:
IMPORTANT NOTE: Due to architectural constraints in some of our older interfaces, once you update the firmware in one, it will no longer be compatible with older versions of VCDS on cars that use CAN bus for diagnostics. You will have to use version 16.3 or newer from that point on and won't be able to revert to the previous release version, so don't download this and update your interface firmware unless you're willing to take some risk with a brand-new version that isn't even full public "Beta" yet.
We would appreciate it if you folks did not spread the following link (or the the software itself) around. All support for this TEST version will be right here, in this forum, and nowhere else. Not via e-mail, not over the phone.
If you don't have a really late model car that either doesn't work with your HEX+CAN interface, or that's missing ROD files, there's no compelling reason to download and install this.
By downloading and installing this software, you acknowledge that you've read everything I posted above.
If you have questions about the software itself, please post them right here in this thread.
Please post Auto-Scans from this software in the Reference Scans section of the forum.
NOTA IMPORTANTE: Debido a las limitaciones arquitectónicas en algunos de nuestros interfaces más antiguos, una vez que se actualice el firmware en él, ya no será compatible con las versiones anteriores de VCDS en los coches que utilizan el bus CAN para el diagnóstico. Tendrá que utilizar la versión 16.3 o posteriores partir de ese momento, no podrá volver a la versión anterior, por lo que no se descargue y actualize el firmware de la interfaz a menos que esté dispuesto a aceptar el riesgo de una nueva versión que no es aún completa "Beta" público todavía.
Agradeceríamos que no se extiendan el siguiente enlace (o el software en sí) por ahí. Todo el soporte para esta versión de prueba será aquí, en este foro, y en ninguna otra parte. No a través de correo electrónico, ni por teléfono.
Si no tiene un modelo de coche muy antiguo que, o bien no funciona con su HEX + interfaz CAN, o que falta archivos ROD, no hay ninguna razón de peso para descargar e instalar esta versión.
Al descargar e instalar este software, reconoce que ha leído todo lo publicado anteriormente.
Si tiene alguna pregunta sobre el software en sí, por favor publíquelo en este hilo.
Por favor, ponga Auto-Scans de este software en la sección de exploraciones de referencia del foro.
Vamos que me espero a la release oficial y sea otro el conejillo de indias
Posteado usando la trócola 4G
Con lo que mola ser conejillo y trastear jejejejCita:
Si, la he puesto y no lo hace.Cita:
Volveré a probar con vagcom a ver si algo no esta bien.
Enviado desde mi Aquaris E5 mediante Tapatalk
En el Discover has visto si lo tienes para activar o desactivar? Lo mismo hay esta la opción desactivadaCita:
Lo he mirado, ni sale jejeje.
A mi tampoco me funcionó la primera vez, lo volví a repetir pero esta vez hice la codificación con el mando del espejo en la R y funcionó
