Ayuda fallos en passat bkp con vag
HOLA ME SALE ESTO DESPUES DE LOS AVISOS DEL MUELLE Y GASES DE ESCAPE LA EGR LA DESMONTE Y TIENE OLLIN CON ACEITE NO ES SECA NO SE SI ES NORMAL EL CAUDALIMETRO LO LIMPIE CON ALCOHOL Y NO PARECE ESTAR MAL LOS TUBOS DE LA CAJA DE VALVULAS NO TIENEN FUGAS EN MI PARECER .
BUENO EL COCHE ARRANCA BIEN NO DA TIRONES Y CONSUMO NORMAL,EL TURBO LO LIMPIE ACE POCO,ALGUN CONSEJO DE COMO COMPROBAR LA EGR Y CAUDALIMETRO POR QUE CREO QUE SEA LA CAJA DE VALVULAS QUE NO REGULAN BIEN,SI SE COMPRUEBAN EN LA 3 Y 11 COMO INTERPRETAR LOS VALORES Y SI EL MOTOR ESTA EN RELENTIN MUCHAS GRACIAS AQUI EL LOG
MAddress 01: Engine Labels: Redir Fail!
Part No W: 03G 906 018 HW: Component: R4 2.0l PPD1.1 G 9722
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00987 572 90606
3 Faults Found:
16786 - EGR System: Excessive Flow
P0402 - 006 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 2
Fault Frequency: 4
Reset counter: 224
Mileage: 78889 km
Time Indication: 0
Date: 2010.11.28
Time: 12:54:40
Freeze Frame:
RPM: 1792 /min
Text: 32
Text: Nm
Text:
Mass Air / Rev.: 0.0 mg/str
Text: 32.8 %
Text:
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 006 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 224
Mileage: 78891 km
Time Indication: 0
Date: 2010.11.28
Time: 12:58:23
Freeze Frame:
Text:
Text: 0
Text: Nm
Text:
Text: 1231
Text: hPa
Text:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 006 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 225
Mileage: 78893 km
Time Indication: 0
Date: 2010.11.28
Time: 12:59:39
Freeze Frame:
RPM: 2272 /min
Text: 200
Text: Nm
Text:
Voltage: 14.46 V
Text: 1889
Text: hPa
La EGR va regulada con un motor paso a paso, entonces, aunque la tengas recien limpia, si el motorcillo esta fastidiado, te da la brasa.
como compruebo ese motor que muebe la mariposa
