Ayuda errores VAGcom
Al pasar el scan del vagcom me da estos errores alguien me ayuda con ellos:
Mi coche es un Scirocco MY2009, con volante 2010, RNS a posteriori,Bluetooth OEM a posteriori.
VCDS Version: Beta 812.4
Data version: 20090214
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 77
VIN:
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: Not registered 0001
Address 01: Engine (CAX) Labels: None
Part No SW: 03C 906 016 B HW: 03C 906 016
Component: MED17.5.5 G 2204
Revision: LCH02--- Serial number: --************
Coding: 0000072
Shop #: WSC 00020 790 00000
ASAM Dataset: ------------------------- ------
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 743B40F5092500FD2E0C02EC902100403500
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 5K0 907 044 BD HW: 5K0 907 044 BD
Component: Climatronic H14 0608
Revision: 00003001
Coding: 0000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Climatronic A01001
ROD: N/A
No ASAM data available for this controller:"EV_Climatronic" .
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000009407058
Coding: F7AE0F0300041A0F67968E0019000000000BFF070040013500 0000000000
Part No: 1K8 955 119 B
Component: Wischer 180209 022 0602
Coding: 00038805
Shop #: WSC 00020
Part No: 1K0 955 559 AH
Component: RLS 240309 054 0402
Coding: 00209133
Shop #: WSC 00020
1 Fault Found
00061 - Footwell Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 157
Mileage: ---km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.65 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 1K0 919 475 F HW: 1K0 919 475 F
Component: PARKHILFE 005 1506
Revision: 00005000 Serial number: 0 263 004 300
Coding: 100001
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0G AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D00V09R
Coding: 0012359
Address 16: Steering wheel Labels: Redir Fail!
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 055 0111
Coding: 0000732
Part No: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K8 920 870 F HW: 1K8 920 870 F
Component: KOMBIINSTRUMENT VDD 2444
Revision: V0005000 Serial number: *************
Coding: 0005103
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K093120B16
Coding: E9A11F06400212004000
Shop #: WSC 03951 572 72972
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 157
Mileage: ***
Time Indication: 0
Date: 2000.00.00
Time: 11:32:24
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 2444
Revision: V0005000 Serial number:*****
Shop #: WSC 00000 000 00000
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667387025
Coding: 010000
Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl
Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
Component: RNS-MID H11 3810
Revision: AB001001 Serial number: ****
Coding: 0C000402040000210000
Shop #: WSC 05314 000 00000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1Q0 959 701 F HW: 1Q0 959 701 F
Component: Tuer-SG 008 2021
Coding: 0020535
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H17000
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 81900A000283CC7F3F028E0F7008CACE903C00
Part No: 1K8 951 605
Component: LIN BACKUP HORN H09 9002
Part No: 1K8 951 171
Component: DWA-Sensor 001 0104
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1Q0 959 702 F HW: 1Q0 959 702 F
Coding: 0020790
1 Fault Found
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
012 - Electrical Fault in CircuitEsta se que es por que tengo una luz fundida de las luces de cortesia
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 K
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000015
Address 56: Radio (J0506) Labels: 1T0-035-680.lbl
Revision: AB001001 Serial number: *********
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 B HW: 1Z0 035 729 B
Component: FSE_2P7x H31 0050
Revision: 00000001 Serial number: 00000005014419
Coding: 0000455
Última edición por wolfxam; 22/12/2010 a las 15:17
