hola chicos hoy le e ech un test al coche con el vag com y nuncA me aparecieron tantos errores echazle un vistazo a ver si me decis cual es cual cada uno GRACIAS
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 038 906 018 FB
Component: 1,9l R4 EDC G000SG 2170
Coding: 00005
Shop #: WSC 06402
4 Faults Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17849 - EGR Valve (N18): Open Circuit or Short to Ground
P1441 - 35-10 - - - Intermittent
17958 - Charge Pressure: Control Deviation
P1550 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 11111
No fault code found.
Address 08 -------------------------------------------------------
Controller: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
Address 15 -------------------------------------------------------
Controller: 1J0 909 609
Component: N AIRBAG VW3 SG 0002
Coding: 00078
Shop #: WSC 06402
4 Faults Found:
01218 - Side Airbag Igniter: Passenger Side (N200)
32-10 - Resistance too High - Intermittent
01217 - Side Airbag Igniter: Driver Side (N199)
00588 - Airbag Igniter: Driver Side (N95)
Address 17 -------------------------------------------------------
Controller: 6K0 920 801 F
Component: 6K-KOMBIINSTR. VDO V02
Coding: 07142
Shop #: WSC 00000
IMMO-IDENTNR: SEZ7Z0A0963532
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 56 -------------------------------------------------------
Controller: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
4 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
00853 - Loudspeaker(s): Rear
00856 - Radio Antenna
00779 - Outside Air Temp Sensor (G17)
16-00 - Signal Outside Specifications
End -------------------------------------------------------
