Parámetros de uso en SVCDEC
Código:
use: "FileName" [command] [params]
COMMAND:
   brt - brute force all lines and find vars : Z & P
   enc - encode lbl file and save to filename.clb
PARAMS:
   -lang=[en|de|ru] , def=de
   -method=[1|2|3] , def=1 , preset of vars : P & Z
   -keymet=NUM [1....8]
   -showlinenum - show line numbers , def=0
   -showallchar=[0|1] - show all chars (0..255) , def=1
   -findshowall=[0|1] - def=0
   -findline=NUM
   -findtxt='TEXT'
   -finddecode=NUM (0..255)
   -maxlines=NUM (def = 0)
   -showonlyerror
   -save  - save decoded file to basename(FileName).lbl , to current path
   -saveto='pathname' - save decoded file to basename(FileName).lbl
   -metvarz=NUM (0..255) - var method key pos Z or -z=22
   -metvarp=NUM (0..255) - var method key pos P or -p=3
   -fastbrt  - brute force only use key pos = (0..60) & (240..255)
simplzz:
   SVCdec.exe 'd:\7L6-9.clb' -save
   SVCdec.exe 'C:\svcdec\1\i\0AW-927-156.clb' -method=3 -saveto="C:/svcdec/1/o/"
   SVCdec.exe 'd:\7L6-9.clb' brt -saveto="results/" -maxlines=50 -fastbrt
   SVCdec.exe 'd:\7L6-9.clb' -saveto 'results/'
   SVCdec.exe 'd:\7L6-9.clb' -method=1
   SVCdec.exe 'd:\7L6-9.clb' -p=3 -z=250 -save
   SVCdec.exe 'd:\7L6-9.clb' -showlinenum
   SVCdec.exe 'd:\7L6-9.clb' brt -findline=10
   SVCdec.exe 'd:\7L6-9.clb' brt -maxlines=15 -lang=de -findshowall
   SVCdec.exe 'd:\7L6-9.clb' brt -findline=65 -finddecode=33
   SVCdec.exe 'd:\7L6-9.clb' brt -fastbrt
   SVCdec.exe 'd:\7L6-9.lbl' enc -z=33 -p=3
Note:
       -saveto="PATH" - in path use only `/`; `C:/path1/path2/` or  `path1/path2/`
       -method=3 =>  p=3 & z=233
       -method=2 =>  p=2 & z=250
       -method=1 =>  p=3 & z=250
Def use :
    >SVCdec.exe "d:\7L6-9.clb" -maxlines=5
    check result => good => add `-save` :)
    if error  => add command `brt` :
    >SVCdec.exe "d:\7L6-9.clb" brt -maxlines=50 -fastbrt -lang=en
    check result => if bad  => remove `-fastbrt` and edit `-lang=de` => check result  => if bad remove `-maxlines`
