LOG POLO
WENAS a ver si alguien me puede decir que son los siguientes errores.
GRACIAS.
Saturday,18,October,2008,17:02:46:59303
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 37 44 45 46 56 76
VIN: WVWZZZ9NZ8Y222288
Address 01: Engine Labels: None
Part No SW: 03C 906 024 AD HW: 03C 906 024 F
Component: MARELLI 4HV 2485
Coding: 0000071
Shop #: WSC 00788
2 Faults Found:
28827 - No Communication with Instrument Cluster
U0155 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 0
Reset counter: 25
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Freeze Frame:
Bin. Bits: 00000000
Load: 39.0 %
Lambda: 2.0 %
Speed: 0.0 km/h
Temperature: 88.0°C
Absolute Pres.: 436.9 mbar
RPM: 774 /min
16400 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28): Incorrect Correlation
P0016 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 17
Mileage: 0 km
Time Indication: 0
Date: 2000.01.01
Time: 00:00:00
Freeze Frame:
Bin. Bits: 00000000
Load: 39.0 %
Lambda: -3.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Absolute Pres.: 448.8 mbar
RPM: 729 /min
Readiness: 0000 0000
Address 44: Steering Assist Labels: None
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10140
Shop #: WSC 00788
No fault code found.
Address 56: Radio Labels: 1K0-035-1xx-56.LBL
Part No SW: 6Q0 035 152 E HW: 6Q0 035 152 E
Component: Radio 9NK 0004
Coding: 0020200
Shop #: WSC 00788
3 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
00871 - Bass Speaker Front Right (R23)
01044 - Control Module Incorrectly Coded
000 - -
End --------------------------------------------------------------------------------------------------
Re: LOG POLO
algunas marelli son muy jodidas
- No puedes responder temas
Reglas del Foro
