Includes partial support for VW Crafter vans. Communications with all control modules; functions supported: Control Module ID and Advanced ID, Fault Codes (Read and Clear), Supported Codes, Security Access, and Adaptation. Other functions such as Measuring Values, Output Tests, and Basic Settings will be added in future versions.
New, more universal Airbag Coding Assistant.
New "Upload Debug/Log File" function in Applications Dialog
Completely revised and expanded ROD (ODX) Data.
New USB Drivers. Now compatible with the latest PCs which use Fresco Logic USB3 chipsets.
Re-factored DTC routines which interpret DTC data, including enhanced interpretation of status byte for DTCs in UDS modules.
New area to display additional info for Basic Settings.
Added data types 0B, 0D, 0F to Generic OBD-II Mode 9.
New version of LCode. Thanks to Niels in Denmark!.
Revised and expanded Label Files. Thanks to Sebastian!
Many other small fixes and improvements, as well as everything which was introduced in Beta Versions 11.2 - 11.10.
