Resultados 1 al 4 de 4
Tema: (ayuda) fallo motor octavia 2
    Avatar de doc
    Nº de Usuario: 8502
    11-may-2011
    Rias BAixas
    skoda octavia rs tfsi bwa
    Predeterminado (ayuda) fallo motor octavia 2
    Hola, hoy se me ha encendido la luz de fallo motor, antes de encenderse al relentin se me aceleraba solo y despues se encendio, estaba entre las 1000 y 1500 r.p.m oscilando,
    le he hecho un autoscan y me ha dado esto :
    VCDS Version: Release 11.11.0
    Data version: 20111111
    Sunday,20,November,2011,22:13:01:37412
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 76
    VIN: TMBEF61Z082199751 Mileage: 66500km/41321miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 1Z0 907 115 D HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH16--- Serial number: SKZ7Z0H4966069
    Coding: 0203000318070160
    Shop #: WSC 73430 790 00000
    VCID: 3669577C415C62E
    3 Faults Found:
    004243 - Bank 1; Fuel Measuring System 2
    P1093 - 008 - Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 66470 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:44:07
    Freeze Frame:
    RPM: 1613 /min
    Load: 11.8 %
    Speed: 43.0 km/h
    Temperature: 87.0°C
    Temperature: 45.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.970 V
    001287 - Idle Control System RPM
    P0507 - 001 - Higher than Expected. - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 66493 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:30:58
    Freeze Frame:
    RPM: 767 /min
    Load: 14.1 %
    Speed: 0.0 km/h
    Temperature: 95.0°C
    Temperature: 39.0°C
    Voltage: 13.970 V
    008583 - Bank 1; System too Lean at Idle
    P2187 - 004 - - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 66493 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:32:28
    Freeze Frame:
    RPM: 1175 /min
    Load: 13.7 %
    Speed: 0.0 km/h
    Temperature: 91.0°C
    Temperature: 46.0°C
    Voltage: 13.970 V
    Readiness: 0000 0000
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0104
    Revision: 00H35001
    Coding: 143B601C092B0003281206E9901A00416C00
    VCID: 74EDAD74D7A030E
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1Z0 907 044 AB HW: 1Z0 907 044 AB
    Component: ClimatronicPQ35 120 0600
    Revision: 00120022 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 76E9977C01DC22E
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000005832589
    Coding: E18E0F111004140043110D000000000000097F065C00000C00 0000000000
    Shop #: WSC 73430 790 12345
    VCID: 336F6E68522E776
    Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 200608 022 0601
    Coding: 00055223
    Shop #: WSC 73430
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 240608 054 0402
    Coding: 00471277
    Shop #: WSC 73430
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA
    Component: Q2 AIRBAG VW8 027 0900
    Revision: 11027000 Serial number: 003B5D15DDBW
    Coding: 0020786
    VCID: 6BDFB6084A9EEF6
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BK HW: 1K0 953 549 BK
    Component: J0527 051 0101
    Coding: 0002042
    Shop #: WSC 08769 572 83239
    VCID: 7CFD85543FF078E
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1Z0 920 842 C HW: 1Z0 920 842 C
    Component: KOMBIINSTRUMENT VD1 1612
    Revision: V1612036 Serial number: SKZ7Z0H4966069
    Coding: 0007101
    VCID: 37775A7846569B6
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K086100994
    Coding: E9817F0E0002021302
    VCID: 356B50705C5A696
    2 Faults Found:
    01305 - Databus for Infotainment
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 49
    Reset counter: 134
    Mileage: 66470 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:44:11
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 133
    Mileage: 66470 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:44:16
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VD1 1612
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1T0 959 701 H HW: 1T0 959 701 H
    Component: Tuer-SG 006 1203
    Coding: 0000244
    VCID: 3C7D45547F70B8E
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 M
    Component: EPS_ZFLS Kl.074 H08 1901
    Shop #: WSC 73430 000 90108
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 80801A085283007F3F02850500084F01807C00
    VCID: 830F7EA8C20E876
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1T0 959 702 H HW: 1T0 959 702 H
    Coding: 0000244
    VCID: 3D7B4850646AB16
    Address 55: Xenon Range Labels: 1T0-907-357.lbl
    Part No: 1T0 907 357
    Component: Dynamische LWR 0003
    Coding: 0000007
    VCID: F4ED2D7497A0B0E
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
    Component: Tuer-SG 006 1301
    Coding: 0000144
    Shop #: WSC 73430 790 1012544
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
    Coding: 0000144
    VCID: 387559444B4894E
    Address 76: Park Assist Labels: 1Z0-919-283.lbl
    Part No SW: 1Z0 919 283 C HW: 1Z0 919 283 C
    Component: Parkhilfe 8-Kan H04 0020
    Coding: 0000001
    VCID: 3E794F5C696CAAE
    Nº de Usuario: 13555
    18-abr-2012
    Badajoz
    seat ibiza
    hola mira esto
    17501/P1093/004243 - Banco 1; Sistema de combustible de medición 2: Avería
    síntomas posibles
    * Pérdida de potencia
    * Fallo de encendido (s)
    * Stalling
    posibles causas
    * Presión de combustible insuficiente / sobrepasar / fluctuante
    * Bomba de combustible (sistema de alta presión) defectuoso
    Combustible * Regulador de presión de la válvula (N276) defectuoso
    posibles soluciones
    Consultar presión de combustible (en los motores FSI sistema de combustible de alta presión y baja)
    * Comprobar la bomba de combustible (sistema de alta presión)
    * Verificar la presión de válvula de combustible Regulador (N276)
    * Compruebe el filtro de combustible y filtro en la bomba de combustible Cubierta
    Notas especiales
    * Cuando se encuentra en 2.0 litros TFSI:
    o Compruebe la presión de combustible
    o Compruebe TSB / TPL 2008753, la incompatibilidad entre la válvula del regulador de presión de combustible (N276) y el software de ecus.
    18619/P2187/008583 - Banco 1, Sistema demasiado pobre en ralentí
    posibles causas
    Inyectores de fuga / bloqueado
    Fuga de aire de admisión (después MAF)
    escape de fugas
    posibles soluciones
    Compruebe Mass Air Flow Sensor (G70)
    Compruebe Inyector (s)
    Compruebe la bomba de combustible
    Comprobar filtro de carbón activo (EVAP) Válvula Solenoide Sistema 1 (N80)
    Notas especiales
    Cuando se encuentra en la NAR 2.0T RVUTB (BPY) Verificación: 01/09/03 o 2018919 para la válvula del respiradero del cárter actualizado
    Si la válvula de ventilación es deficiente, el vacío del motor completo se encuentra normalmente al quitar el tapón del aceite al ralentí.
    alomejor tambien tiene algo que ver con la sonda lambda
    saludos
  3. El Siguiente Usuario Agradeció a sport16v Por Este Mensaje:
    doc (05/12/2012)
    Avatar de doc
    Nº de Usuario: 8502
    11-may-2011
    Rias BAixas
    Ok, gracias. Revisare los manguitos de admisión sino para el taller
    Avatar de doc
    Nº de Usuario: 8502
    11-may-2011
    Rias BAixas
    Al final era la valvula pcv
