Chassis Type: 1K0
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 CB HW: 028 101 190 0
Component: R4 1,9L EDC G000SG 6176
Revision: 12345678 Serial number:
Coding: 0000071
Shop #: WSC 00046 412 352256
VCID: 65CBC030AC7AD96
1 Fault Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 56.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Bin. Bits: 00001000
Temperature: 16.2°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 AB HW: 3C8 937 049 AB
Component: Bordnetz-SG H57 3204
Revision: 00H57000 Serial number: 00000004104344
Coding: E58B0F2600041000081D00000000000000097F075C04000C00 0000000000
Shop #: WSC 00037 781 18225
VCID: 71E3A46068B2056
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00037
Subsystem 2 - Part No: 1K0 955 559
Component: RegenLichtSens 002 0303
Coding: 00399666
Shop #: WSC 00037
1 Fault Found:
03780 - Fall-Back Mode for Brake Light Control
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00111110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 75
Mileage: 62773 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.75 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5P0 919 475 C HW: 5P0 919 475 A
Component: PARKHILFE 8K H07 0005
Revision: -------- Serial number: 89041011004632
Coding: 000001
Shop #: WSC 00000 000 00000
VCID: 3B7F4648BA7EBF6
1 Fault Found:
01312 - Powertrain Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 254
Reset counter: 65
Mileage: 76563 km
Time Indication: 0
Date: 2000.00.00
Time: 15:48:34
Freeze Frame:
Temperature: 0.0°C
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: 01 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0M6FE0
Coding: 0012337
VCID: 31636460A832456
2 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01284 - Side Airbag; Drivers Side; Disabled
000 - -
