Resultados 1 al 2 de 2
Tema: Errores encontrados con auto-scan
    Nº de Usuario: 205
    02-jul-2008
    aLGeCiRaS
    Vw Bora Tdi 100 CV
    Predeterminado Errores encontrados con auto-scan
    Pues eso ...le he hecho un scaneo y me han salido unos cuantos errores..a ver si alguien me aclara de que van ..Un saludo
    Chassis Type: 1J - VW G/J/B Mk4
    Scan: 01,02,03,08,15,17,19,22,35,46,56
    Address 01 -------------------------------------------------------
    Controller: 038 906 019 DD
    Component: 1,9l R4 EDC 0000SG 1518
    Coding: 00002
    Shop #: WSC 01266
    WVWZZZ1JZ3W598435 VWZ6Z0C0044697
    1 Fault Found:
    17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
    P1256 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019458
    Shop #: WSC 01266
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 3B1 907 044 C
    Component: CLIMATRONIC C 2.0.0
    Coding: 11000
    Shop #: WSC 01266
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    37-00 - Faulty
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 1J0 920 826 C
    Component: KOMBI+WEGFAHRS. RB8 V28
    Coding: 07112
    Shop #: WSC 00000
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to B+ - Intermittent
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01266
    Address 46 -------------------------------------------------------
    Controller: 1C0 959 799 B
    Component: 18 Komfortgerát HLO 0003
    Coding: 00259
    Shop #: WSC 01266
    1 Fault Found:
    00931 - Locking Module for Central Locking: Rear Right (F223)
    27-10 - Implausible Signal - Intermittent
    End -------------------------------------------------------
    Vw Bora TDI 100 C.V
    Administrador
    Avatar de pas-pas
    Nº de Usuario: 4
    20-jun-2008
    En el centro, a la derecha
    Predeterminado Re: Errores encontrados con auto-scan
    Pues todos los errores que te aparecen son ocasionales. Bórralos y vuelve a comprobar pasado un par de días si siguen ahí (no deberían)
    El del climatizador es muy típico. Hace referencia al reposicionamiento de las compuertas. Por lo visto se debe a que en el momento en que se están reposicionando las compuertas se quita el contacto y se quedan a medias generando el error.
    El del motor es un corto a masa (ocasional) del sensor de refrigerante (G62). El del cuadro hace referencia al mismo fallo del motor (lógico si el sensor del motor acaba comunicándose con el cuadro para activar o no el chivato correspondiente)
    El error del cierre centralizado en el módulo confort corresponde al cierre de la puerta trasera derecha (se ha detectado una señal no "entendible" y ha generado fallo ocasional.
    En resumen, lo comentado al principio: borra los fallos y vigilalos dentro de un par de días (o tras haberlos borrado con otro autoscan)
