antes de nada, Gracias por la ayuda tan rapida, lo he intentado con las 2 llaves y nada, he borrado las averias con el vag y sigue igual, vuelvo a hacer el autoscan y siguen saliendo las averias (copy paste)
Código:
VCDS Version: Release 11.11.3
Data version: 20120401
Saturday,05,October,2013,20:10:59:32264
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 215390km/133837miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 018 S
Component: 1,9l R4 EDC 00SG 1614
Coding: 00002
Shop #: WSC 06435
VCID: 2649E841C2FC2C9
3 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
00626 - Glow Plug Indicator Light (K29)
31-10 - Open or Short to Ground - Intermittent
00527 - Intake Manifold Temperature Sensor (G72)
30-00 - Open or Short to Plus
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB980A1DA2CB49
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
35-00 - -
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
35-00 - -
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04143
Shop #: WSC 06435
VCID: 2953E37DD3E2031
No fault code found.
Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
Part No: 8D0 959 655 C
Component: Airbag 7 Audi 0303
Coding: 00104
Shop #: WSC 06435
VCID: 36693801125C5C9
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 860 E
Component: B5-KOMBIINSTR. VDO D07
Coding: 00040
Shop #: WSC 00000
VCID: 32610411FE34409
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0V0187951
IMMO-IDENTNR: AUZ7Z0V0187951
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 D
Component: ZV-Pumpe, Funk D03
Coding: 12864
Shop #: WSC 65535
VCID: 55AB9F8DAF1A771
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186
Component: Radio D01
Coding: 00201
Shop #: WSC 06435
VCID: DDBB07AD572A2F1
el siguiente autoscan dice lo siguiente:
Sunday,06,October,2013,15:44:52:32264
Coding: 00002
Shop #: WSC 06435
5 Faults Found:
00532 - Supply Voltage B+
27-00 - Implausible Signal
01237 - Fuel Shut-Off Valve (N109)
31-00 - Open or Short to Ground
P1570 - 35-00 -
00668 - Supply Voltage Terminal 30
27-10 - Implausible Signal - Intermittent
Readiness: N/A
Shop #: BB 24548
2 Faults Found:
35-00 - -
35-00 - -
Coding: 04143
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
Coding: 00040
Shop #: WSC 00000
Coding: 12864
Shop #: WSC 65535
Coding: 00201
Shop #: WSC 06435
pues con esta información espero que puedan ayudarme. gracias de antemano.
por cierto, la reparación que realice fue la siguiente: cambio de junta de culata, distribucion, cambio de manguitos de refrigeracion, limpieza de las valvulas N18, N75 y EGR, desmontaje del enfriador de aceite para comprobar que no estubiese comunicando aceite al refrigerante y nada mas, no he cambiado ninguna pieza electronica.
