Código:
Wednesday,09,October,2013,07:47:32:60191
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ7NXXXXXXXXX License Plate: 9999 ZZZ
Mileage: 14030 Repair Order:
Chassis Type: 7N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 37 42 44 46 4C 52 53
55 56 61 62 6C 6D 72 A5 BE BF
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BE-Sliding Door Left -- Status: OK 0000
BF-Sliding Door Right -- Status: OK 0000
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 L HW: 03L 906 018 M
Component: R4 2,0L EDC H27 9230
Revision: 44H27--- Serial number:
Coding: 001D003A042401080000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01103L906018L 003005
ROD: EV_ECM20TDI01103L906018G.rod
VCID: 336ECE759ADE7786591-8066
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 057 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3102
Revision: 05551213 Serial number: 00001201180288
Coding: 0000020
Shop #: WSC 00020 790 00000
VCID: 234E3E35E23EE706A91-8076
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 N HW: 7N0 614 109 N
Component: J104 C3 450M VD5A 0021
Revision: --H07--- Serial number: 00000005285925
Coding: 0027527
VCID: 3874F9594BB894DE6C3-806D
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 FK HW: 5K0 907 044 FK
Component: Clima-Sharan H18 0204
Revision: 00001003
Coding: 0200004509
ASAM Dataset: EV_ClimatronicSharan A01005
ROD: EV_ClimaAutoSharaBasis_VW36.rod
VCID: 79F23C5DF8324DD6D3D-802C
Subsystem 1 - Part No SW: 7N0 907 049 B HW: 7N0 907 049 B
Component: KBT-H 004 0102
Serial number: 20120123000000057035
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0064
Revision: BC021001
Coding: 40590A3B89251AC0500800C8140089E443559388626D29626484C72000C1
VCID: 3E78EF41A99CAAEEA6F-806B
Subsystem 1 - Part No SW: 7N1 955 119 A HW: 7N1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 111218 31 0032
Coding: 004DBD
Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559
Component: RLFS 021 0024
Coding: 0280BB
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261202401035
Coding: 34830A
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_SE36.rod
VCID: 448C9DA9CF70C03EF0B-8011
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00Z H10 0014
Serial number: 003LGP1EVNNS
Coding: 00305A
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428_VW36.rod
VCID: 3F869245A696A3E6AD9-806A
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60159401149DE
Coding: 000000
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS6012E90114DDH
Coding: 000000
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS6020D00014DD6
Coding: 000000
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS606FA001149DK
Coding: 000000
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS60A823FF139DU
Coding: 000000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 CF HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20120125200555
Coding: 399A240000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 70E40179AB480C9E643-8025
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 1P0 959 538 B HW: 1P0 959 538 B
Component: E221__MFL-TAP H02 0102
Coding: E30000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 7N5 920 870 E HW: 7N5 920 870 E
Component: KOMBI H03 0609
Serial number: 00000000000000
Coding: 141F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3972FC5DB8B28DD693D-806C
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 C
Component: Zuheizer 051 2730
Revision: 00051000 Serial number: 09022126000000
Coding: 0000041
VCID: 346CCD6957D070BE40B-8061
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H41 1623
Revision: H41 Serial number: 160112F1002122
Coding: 468202
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0609
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD093110D94764EAA7-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661720376
Coding: 020000
VCID: 29522C1D40123D56E3D-807C
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 5P0 035 191 J HW: 5P0 035 191 J
Component: RNS315-EU H51 0319
Serial number: SEZAZ2L9145613
Coding: 040004410400001010000005
Shop #: WSC 44444 444 00225
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3260CB7165C47E8E527-8067
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_X045 X045
2 Faults Found:
1048646 - Rear View Camera
B1102 31 [008] - No Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 2
Reset counter: 104
Mileage: 13518 km
Date: 2017.14.28
Time: 10:26:03
1048641 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 87
Mileage: 4313 km
Date: 2002.14.24
Time: 12:05:57
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 E HW: 7N0 959 793 A
Component: TSG FA H04 0400
Revision: Serial number: 0000123791875
Coding: 01112E209000411011
VCID: 448C9DA9C770C03EF0B-8011
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.324 1002
Revision: 1AH03734 Serial number: 00120130016001
Coding: 0000258
VCID: 3C7CE5497F80B8FE88B-8069
Address 4C: Tire Pressure II
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 E HW: 7N0 959 792 A
Component: TSG BF H04 0400
Revision: Serial number: 0000123796344
Coding: 01112C209E00411011
VCID: 438E9EB5C27EC706C91-8016
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000630177
Coding: 0024167
VCID: 356AF06D5CAA69B6775-8060
Address 55: Xenon Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 068200000B000000
Shop #: WSC 00020 999 39850
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: 3776FA658EA69BA6659-8062
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B
Component: LeiMo links H06 0001
Coding: 3B0000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B
Component: LeiMo rechts H06 0001
Coding: 3B0000
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1623
Coding: 030F1859
VCID: F1E2847D28428596EBD-80A4
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 121
Mileage: 13774 km
Time Indication: 0
Date: 2018.14.06
Time: 23:38:42
Address 62: Door, Rear Left (J388) Labels: 7N0-959-794.clb
Part No SW: 7N0 959 794 F HW: 7N0 959 795 B
Component: TSG HL H03 0400
Revision: Serial number: 0000123722586
Coding: 01006C200000411001
VCID: 468887A1F14CF22EEEF-8013
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7N0 907 441 A HW: 7N0 907 441 A
Component: J772__Rearview 0120
Revision: 00H10000 Serial number: 525 PA8J210412
Coding: 0020011
VCID: 2F66C205BEF653663D9-807A
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7N0 959 107 C HW: 7N0 959 107 A
Component: HDSG-Modul H11 0804
Revision: 41011001 Serial number: 013200566
Coding: 0733334002
ASAM Dataset: EV_HDSGVW428 201133
ROD: EV_HDSGVW428.rod
Address 72: Door, Rear Right (J389) Labels: 7N0-959-794.clb
Component: TSG HR H03 0400
Revision: Serial number: 0000123718734
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H08 0300
Serial number: 0168313918
Coding: 01010100010202100200040000000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
Address BE: Sliding Door Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 A HW: 7N0 959 244 A
Component: Schiebetuer_l 005 2314
Serial number: 11490548
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
Address BF: Sliding Door Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2314
Serial number: 11491190
ROD: EV_AST.rod
