Resultados 1 al 2 de 2
Tema: ayuda scan errores malfunction 1010
    DISIGTD
    Guest
    Predeterminado ayuda scan errores malfunction 1010
    hola os pego un reporte para q me echis una mano para solucionar estos errores aviso e puesto un mfd2 dvd q no venia de serie un saludop
    Wednesday,07,January,2009,10:07:15:59303
    VAG-COM Version: Release 704.1
    Data version: 20070422
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 57 7D
    VIN: WVWZZZ................... Mileage: 63710km/39587miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    57-TV Tuner -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 016 CB HW: 028 101 190 0
    Component: R4 1,9L EDC 0000SG 6176
    Coding: 0000071
    Shop #: WSC 09027
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0021121
    Shop #: WSC 00046
    Address 08: Auto HVAC Labels: 1K0-907-044.LBL
    Part No: 1K0 907 044 AB
    Component: ClimatronicPQ35 066 0404
    2 Faults Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    008 - Implausible Signal - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    Address 09: Cent. Elect. Labels: 1K0-937-049.LBL
    Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
    Component: Bordnetz-SG H34 0803
    Coding: 81890F060004180F001400001400000000087F075C
    Shop #: WSC 00046
    Part No: 1K1 955 119 B
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00046
    Address 15: Airbags Labels: 1K0-909-605.LBL
    Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
    Component: 07 AIRBAG VW8 013 2100
    Coding: 0012343
    Shop #: WSC 00046
    Address 16: Steering wheel Labels: 1K0-953-549.LBL
    Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
    Component: Lenksäulenmodul 021 0050
    Coding: 0000012
    Shop #: WSC 00046
    Address 17: Instruments Labels: 1K0-920-xxx-17.LBL
    Part No: 1K0 920 861 MX
    Component: KOMBIINSTRUMENT VDD 1014
    Coding: 0003103
    Shop #: WSC 09027
    Address 19: CAN Gateway Labels: 1K0-907-530.LBL
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H09 0110
    Coding: 3D0F0B58070000
    Shop #: WSC 00046
    4 Faults Found:
    00467 - TV Tuner (R78)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 106
    Reset counter: 115
    Mileage: 63633 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:34:45
    01305 - Databus for Infotainment
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 154
    Mileage: 63705 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:07:49
    01300 - Control Module for Navigation with CD-Rom (J401)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 154
    Mileage: 63705 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:07:52
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 154
    Mileage: 63705 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:07:52
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
    Component: IMMO VDD 1014
    Address 37: Navigation Labels: 1K0-919-887-MFD2.LBL
    Part No: 1K0 919 887 F
    Component: Navigation 0028
    Coding: 0000101
    Shop #: WSC 05314
    1 Fault Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.LBL
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0155
    Coding: 0000052
    Shop #: WSC 00046
    Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
    Part No: 1K1 909 144 H
    Component: EPS_ZFLS Kl.2 1502
    Address 46: Central Conv. Labels: 1K0-959-433-46.LBL
    Part No: 1K0 959 433 BK
    Component: 01 KSG 0301
    Coding: 81D80A487F2D8505484A06F010
    Shop #: WSC 00046
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.LBL
    Part No: 1K0 959 702 E
    Coding: 0000052
    Shop #: WSC 00046
    Address 56: Radio Labels: 1K0-035-095.LBL
    Part No: 1K0 035 095 G
    Component: Radio 0028
    Coding: 0040402
    Shop #: WSC 05314
    2 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit - Intermittent
    00821 - Shareware Version. To Decode all DTCs
    011 - Please Register/Activate - Intermittent
    DISIGTD
    Guest
    Unhappy
    hola porfavor ayudarme es urgente
