Intercambie las Bobinas, Limpie las Averías con VAG-COM pero ahora me aparecen los siguiente errores:
VCDS Version: Beta 12.10.3
Address 01: Engine Labels: 03C-906-022-CAX.clb
Control Module Part Number: 03C 906 022 AQ HW: 03C 906 022 B
Component and/or Version: MED17.5.20 G 3641
Software Coding: 0000072
Work Shop Code: WSC 06XX2 785 00X00
VCID: 6BXXXXX14A62XX349C2XX3
4 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 -- 000 -- - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 6
Mileage: 147275 km
Time Indication: 0
Date: 2111.14.07
Time: 07:12:21
Freeze Frame:
RPM: 2111 /min
Load: 56.4 %
Speed: 31.0 km/h
Temperature: 89.0°C
Temperature: 33.0°C
Absolute Pres.: 770.0 mbar
Voltage: 13.716 V
000771 - Cylinder 3
P0303 -- 000 -- Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 4
Mileage: 147287 km
Time Indication: 0
Date: 2111.14.07
Time: 11:48:12
Freeze Frame:
RPM: 3155 /min
Load: 90.2 %
Speed: 70.0 km/h
Temperature: 89.0°C
Temperature: 43.0°C
Voltage: 13.589 V
000785 - Cylinder 11
P0311 -- 000 -- Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 147227 km
Time Indication: 0
Date: 2111.14.05
Time: 20:22:42
Freeze Frame:
RPM: 3911 /min
Load: 88.2 %
Speed: 55.0 km/h
Temperature: 89.0°C
Temperature: 39.0°C
Voltage: 13.716 V
000775 - Cylinder 7
P0307 -- 000 -- Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Mileage: 147275 km
Time Indication: 0
Date: 2111.14.07
Time: 07:12:21
Freeze Frame:
RPM: 2111 /min
Load: 56.4 %
Speed: 31.0 km/h
Temperature: 89.0°C
Temperature: 33.0°C
Voltage: 13.716 V
Readiness: 0010 0101
Última edición por disturbio; 29/01/2014 a las 06:58
