Fallo en mando a distancia
Quisiera que alguien me ayudara a resolver un problema con el mando a distancia de la llave de un skoda octavia.Solo abre con la llave. Gracias.
Synchonisation of the remote control
If the vehicle cannot be unlocked by actuating the remote control system
then it is possible that the code in the key and the control unit in the vehicle
are no longer synchronised. This can occur when the buttons on the radiooperated
key are actuated a number of times outside of the operative
range of the equipment or the battery on the remote control was replaced.
This means it is necessary to synchronise the code as follows:
• Press any button on the remote control.
• Pressing of the button means that the door will unlock with the key
within 1 minute.
Member
Y no será tema de la pila
Desmonta el mando y cambias la pila
Última edición por lordtemon; 09/04/2014 a las 23:43
- No puedes responder temas
Reglas del Foro
