diagnosis turbo
hola a todos, soy carlos varela y este es mi primer post , se trata de un passat 130 que pierde potencia, pasado el vag com me da:
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ3BZ2E259101 License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ2E259101 Mileage: 229550km/142635miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 EP
Component: 1,9l R4 EDC 0000SG 1464
Coding: 00002
Shop #: WSC 05314
VCID: 69D3A5E41387235623D-4A3A
WVWZZZ3BZ2E259101 VWZ7Z0A4314757
2 Faults Found:
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 04255
Shop #: WSC 05311
VCID: 254BE9D4BF1FC736C75-5072
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 H
Component: CLIMATRONIC B5GP 0007
Coding: 17000
Shop #: WSC 05311
VCID: 2649EED8C219CC2ECEF-5000
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 C
Component: 08 AIRBAG VW6 04 0004
Coding: 12344
Shop #: WSC 05311
VCID: 3777339C15B345A6659-4A3A
No fault code found.
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 827 A
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 05125
Shop #: WSC 00000
VCID: 2241F2C8AE31300EA27-5072
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05314
VCID: F0E54880B05D529EE43-5000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 0J Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 05311
VCID: 36693E9812B9BCAE7EF-4A3A
Subsystem 1 - Part No: 1C1959801
Component: 0J Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C1959802
Component: 0J Tõrsteuer.BF KLO 0002
Subsystem 3 - Part No: 1C0959811
Component: 0J Tõrsteuer.HL KLO 0002
Subsystem 4 - Part No: 1C0959812
Component: 0J Tõrsteuer.HR KLO 0002
tambien he hecho log de turbo y es el que sigue:
esta es la url de la foto del grafico
bueno pues nada mas , muchas gracias de antemano por si me podeis decir que debo hacer. chao
- No puedes responder temas
Reglas del Foro
